Results 1 to 3 of 3
Thread: vr keeps draining battery
    vr acclaim 3.8
    Sep 2010
    muswellbrook
    Default vr keeps draining battery
    hello all, i am a first time holden owner, after converting from ford. love my car, but it has its problems. For some reason, the battery will drain completely. this happens every so often, not all the time.i bought a new set of jumpers, which solved the jumpstareting problem, but the battery wont hold charge and the tacho and dash lights are going mental. would this be an earthing problem, or something worse???
    Last edited by firsttimevrowner; 04-09-2010 at 09:37 AM. Reason: part of posted problem was solved
    Dec 2009
    Assuming tat the battery is OK and there is nothing switched on then look for faulty diodes in the alternator
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Alternator regs are good for this. But so are things like boot curtosy lights and glove box lights ect...
    And yes sometimes you will get this on cars when jump starting. Remember to try and earh the jumper lead on the flat car as close to the starter as possible on the engine block. This will help limit that effect but wont cure it. If its a bit pursistant leave it a little while to let the battery take some charge
    Reaper
  1. Something draining my battery!
    By holden_chik in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2008, 12:06 AM
  2. battery draining problem
    By amagll in forum Electrical Wiring / Questions
    Last Post: 16-02-2008, 09:35 AM
  3. draining battery
    By whitey08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2008, 01:37 PM
  4. Battery draining!!!
    By Pure Evil in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 01:02 PM
  5. battery draining.........
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2005, 03:15 PM
