Results 1 to 4 of 4
Thread: Bit of oil in coolant
    VR Berlina
    Mar 2010
    sa
    Default Bit of oil in coolant
    I started the car up today and noticed a bit of white smoke coming out of the exhaust, it's quite a cold day so I thought it was that. I took it for a run up and down the road and came back and it was still smoking a little bit.
    I left it for 10 minutes or so and started it back up and no smoke or anything. I checked under the oil cap and no milky residue or anything.
    I took off the radiator cap and noticed that there's a little bit of oil under the cap and a little bit in the coolant. I started the car to make sure that no air bubbles were coming up which there wasn't.
    I know the Rocker Cover gaskets on the car needs doing that i should be doing soon. Could this be the reason for the little bit of oil in the coolant? or any other reasons?
    VR Executive
    Jun 2010
    Rockhampton
    Head Gasket or maybe the Valley Gasket is blown/leaking-if the oil has a redish tinge to it,it will be the auto trans cooler in the radiator is leaking,had that happen to my old BA Falcon,quite costly as we had to replace the transmission as coolant got into the gearbox,2 months after it ran out of warranty
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
    VR Berlina
    Mar 2010
    sa
    The oil is normal color and it's just a little bit on the top and on the cap. Radiator is fine and not leaking.
    VS acclaim
    Aug 2010
    Mooroolbark
    hopefully you havnt got white goo under your oil cap... keep a watch on the temp guage and good luck
  1. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  2. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  3. sv6 ve 07 coolant
    By jamierawr88 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-02-2010, 02:51 PM
  4. LS1/Gen III Coolant?
    By WAGONBEAST57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2009, 12:13 PM
  5. coolant
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 07:34 PM
