Results 1 to 5 of 5
Thread: Vs missfiring?
    VS Acclaim
    Jan 2010
    Default Vs missfiring?
    Ok, so i've had my vs for almost a year and its been great. Lately when i've started the car the engine shakes as if its misfiring, but i turn it off, wait 2mins and try again, starts and runs fine. But now its happened twice more and i got the check engine light pop up while comming home. Checked the fault code and it came up 42.
    Code 42 - Electronic Spark Timing Bypass Circuit fault (EST)
    After a bit of research and searching through the forums and reciepts, i've kinda narrowed it down to a few things.
    1. Spark plugs - havnt been replaced for 40000 km's
    2. Ignition leads - havnt been replaced for 4yrs
    3. Coil Pack - as far as I know their originals
    Any advice as to which it could be? I can't afford to just go round replacing all of them, even the ignition leads will take a drain on my wallet. Its due for 200k km service soon as well but want to try and get this prob fixed before then. I'm fine to replace everything myself, just need to know what needs to be fixed.
    Any help would be great.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i'll check my manual to see if it has any info, but i would start with fresh fuel. year old fuel would be very stale, maybe even a fresh fuel filter.
    i'll post back soon
    Jul 2006
    Quote Originally Posted by wildeagle44 View Post
    I'd replace the plugs and leads anyway. There's advice on here on on how to test the coil packs with a multimeter, just do a search.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If you can change parts yourself why not do your 200k service yourself too ? On an ecotec its just oil , filters, plugs etc and save your cash to slove the current problem.
    Your code 42 sounds technical, but sounds like it could be DFI related or a sensor in that area ?
    VS Acclaim
    Jan 2010
    Got some second hand coil packs so will give those ago, and decided to get new leads. Will look into plugs when In a week or 2.
  1. Vl still missfiring?
    By Jordo2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-07-2010, 06:36 PM
  2. Vl Missfiring under load.
    Last Post: 23-06-2010, 11:11 PM
  3. missfiring under acceleration
    By b3h3m07h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 01:55 PM
  4. Vn Missfiring??
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 09:53 PM
  5. Missfiring under load??????
    By slick_red_VN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:55 PM
