Results 1 to 5 of 5
Thread: vs v8 won't crank
    vs maloo
    Mar 2010
    Default vs v8 won't crank
    Hey people my vs v8 won't crank properly. It cranks about a 1/8 of a rotation very slowly and then nothing. Put in a new starter motor and ignition switch and still barely cranks and then stops. Battery is only 6 months old and is fully charged. Cleaned up my battery terminals and clamps and clean up earth on motor and still barely anything. Checked all fuses/fusable links and changed starter relay. Imobiliser light goes off when I turn ignition on so I don't thinks it's an issue with imobiliser. Think the battery loom that goes to the starter might be stuffed how can I test it to check if it is stuffed. Any one have any other ideas. Any info would be appreciated. Cheers.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    use jumper leads to effectivly short that + wire out from the battery then crank it. Are you sure the engine to chasis earth strap is good, and the chasis to battery - is good also. You can also prove these by also hooking up the - jumper wire to the engine block back to the battery - terminal.
    Reaper
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    pull out your spark plugs and try it again...and stand back just in case...
    vs maloo
    Mar 2010
    When you say use jumper lead on positive you mean clamp jumper wire directly from +ve on battery to starter motor? Where is the engine to chasis earth strap? I see the an earth strap from battery -ve terminal to chassis.
    VrWagz1's Avatar
    May 2008
    wollongong
    The un-insulated one that goes somwhere near the alternator to a bolt not too far infront on the ingnition module on the gaurd there. I had issues with mine cranking slow at times, found as soon as i grabbed the wire it just pulled straight out of the lug If you havnt checked this, then theres a good chance it may be it.
    And yes +bat to +starter. and -batt to engine block for the other lead.
    Reaper
  1. 304 crank
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 05-06-2009, 11:47 PM
  2. vn crank?
    By kane88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2009, 08:33 PM
  3. crank?
    By esaad in forum V8 Development and Modification
    Last Post: 29-04-2009, 06:52 PM
  4. Which crank do i have in my Vn
    By futronix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2009, 06:55 PM
  5. L67 Crank
    By ADZ124 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 05:49 PM
