Results 1 to 4 of 4
Thread: VS ute Engine truoble?
    VS Commdore ute
    Sep 2010
    Cairns
    Default VS ute Engine truoble?
    hello. I have recently made a 200+ K trip from cairns to mission beach and back.
    once i was back into town my engine light flash on, but quickly flashed off, nothing seemed to change.
    about 20min later, it flashed on again, and when you exelerated, the car made a sound that i cant really discribe, it was like a lawn mower trying to star, it sounded like it was about to stall. skipping beats, hole in the exhaust... (there is no hole) not to sure how to sya it realy.
    i pulled over. turned off the car. waiting about 5 min,then strted it again, the engine light was on at first but went off again. i revend it a little at first, and everything seemed fine, so i reved it a little bit more and it started to make the noise again... i put my girlfriend in the drivers seat and i popped the bonnet and had a listen, i herd a squilling noise at first, but the went away. and when she reved it all i could here was you normal engine noise, but from the side it was lot louder, so i got back in the car, and drove down the road, going from 50 to 60, there was a slight miss beat and the noise cam back but it went not long after.
    im stumped for ideas..
    anyone got any ideas on what it could be
    i had a recent oil change and new filter, and there was some engin oil stop leak put into the oil? could this be causing it? should i drop the oil and place in new filter?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do a codes test as this may indicate a fault code Checking error codes VR/VS (Revised)
    If you added "oil stop leak" that indicates the engine is worn....if so, how many Km's ....also what did the temp gauge read when it was making this noise....is it auto or manual?
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    That Stop Leak Stuff (Oil Additives) Can Damage Your Engine... Told To Me By The Director Of SUPERNATS...
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ive used the nulon stop leak and had no problems, ive since done 2 oil changes since then and the leak is still sealed up
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  3. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  4. cente cap truoble
    By MUNTED6 in forum General
    Last Post: 06-05-2007, 03:43 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
