i have got a 95 vs berlina, when ever i start the car even on freezin cold mrnings the thermo fan comes on a couple of seconds later. also when im driving the thermo cuts in and out and when that happens the engine light comes on. Also one last thing when the car has been running for a while, if im sitting at lights or waiting at a corner it surges bad like it over revs then wants to stall! WHAT IS WRONG!!!!! Please help its soooo annoying.
Take it a sparky.
Firstly do an error check to see if any error codes shows up..Heres a link to a thread that shows you how to do this test.It only takes a couple of minutes, and is as easy as 1.2.3 to do.
---Checking error codes VR/VS (Revised)---also if you scroll down near the bottom of the thread in the link,there are some excellent pictures of how to do this test as well if you are not sure about doing it.
Check ur fuel reg pull the vac line of it n if it's got fuel in it she rooted that way mine done and it was surging ect
As above, check error codes.
Sounds like it may be a coolant temp sensor fault. If signal is lost, the PCM turns on the high speed fan to prevent overheating as it can no longer read engine temp.
This will also have an effect of the fuel delivered to the engine as fuel requirements change with engine temp.
before checking fault codes, check the fan relay in the fuse box. i had the same problem caused by a sticking relay.
Def do the error code check, if the engine light came on while this was going on then there is def a logged fault. The ccolant temp explaination above sounds very reasonable and would explain all your issues.
Yeah, It's The Coolant Temp Sensor.. or The Thermostat Causing Problems With CTS...
