Hey, new to this forum... having trouble with climate control - it wont turn off... Ignition off, key out and the thing still blows air (on full blast). Had to uncouple wiring loom from behind dash.
Any ideas? Have tried another unit but same problem. All fuses in check, so am now at a loss.
PLs help if possible,
Cheers All..
check your fuse's man, exact same thing happened. just replace it
It sounds like the fan speed resistor has failed.
Thanks for that.. i will have a good look.. cheers.
