Gonna remove and give the throttle body a good clean tomorrow arvo, I've got a gregorys manual which says remove and discard the flange gasket. Should I remove and replace or is it okay to re-use and just use some gasket sealant?
Should I use some carby cleaner to clean out the throttle body or can anyone reccomend some products?
cheers
This thread should answer all your questions: CleaningThrottle Body VR V6
