Results 1 to 5 of 5
Thread: L3 Climate Control Troubles
    VL Commodore
    Dec 2008
    Default L3 Climate Control Troubles
    Hi,
    I've been having troubles with my L3 Climate Control. Sometimes it doesn't respond when I change the mode for the vents it doesn't change the airflow but sometimes it does. Also sometimes it will just not turn on, and sometimes half the LCD stays faded and then fully illuminates.
    Are these common problems and anyway to fix, could it be problems with wiring around the car or the actual L3 Climate panel itself.
    It's a VS II Berlina.
    Thanks.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    I would be interested in finding out this problem. Iv just dont the conversion into mine and it only wants to blow at the feet and when its not programed to do it. No idea how to use the controls but i believe its off the feet lol.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The connector into the control module maybe faulty. The control unit maybe broken or on the way out too.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by seq4x4 View Post
    Blowing at the feet is the default position if the vacum side of things is not working. Check all the vacum lines to see if the system can work as it should. If you have vacum then I would look at the vacum pack (coloured tubes connect to it). This thing directs vacum to the flaps that direct air around the different vents.
    VL Commodore
    Dec 2008
    Hi,
    Well I've removed the dash, and the actuator for the Face vents is not getting vacuum when I set it to face, and sometimes randomly it will just get vacuum. So I'm thinking the control unit under the stereo might be causing the problem, I will have to investigate.
    Have checked for vacuum leaks in engine and there is none.
    I also understand there is 2 different versions of the L3 Unit, Have not got much info on it but there are 2 different part numbers,
    that may cause a problem e.g if you don't use the proper L3 Climate unit with the correct vacuum modulator to match?
  1. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  2. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  3. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  4. indicator control arm troubles..
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-12-2007, 06:53 PM
  5. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
