Results 1 to 12 of 12
Thread: Ignition stuck, starter keeps cranking, have to manually turm key back when starting
    VS Executive S2
    Aug 2010
    melb
    Default Ignition stuck, starter keeps cranking, have to manually turm key back when starting
    Hi all, wondering if i need to take my issue to a locksmith, an auto elec or a mechanic?
    When i turn the key to start the car it stays in that position and doesnt automatically fling back. The starter keeps cranking and i have to manually turn the key back just a little for the car to start and to stop the starter from continiously cranking over.
    Ive got the nack of starting the car and turning the key back at the right time, but this needs to be fixed.
    Who do i need to take this to and how much do ya rekkin they'll sting me to fix it?
    Thanks!
    Matty.b is offline VR with 56,000kms genuine
    VR Executive
    Jan 2009
    Coal Fields, Queensland
    when i worked at Toyota had a Celica doing the same thing all it was, was the locksmiths had cut a new key....but done a shit job, is it a new key?
    VS Executive S2
    Aug 2010
    melb
    VS Executive S2
    Aug 2010
    melb
    Also i thought about spraying WD40 in the keyhole/barrel but then i realised that won't help because it seems to be a spring issue.
    When cranked over the key fails to spring back.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Try some WD40 if that doesn't work its either a dodgy wafer in the ignition or the return spring on the tail shaft of the ignition has broken. If it turns out to be either of those options a new ignition barrel is required witch a locksmith will be able to help you with.
    Signature Goes Here
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Not that uncommon in a vs. Most likely up for a new ignition barrel which is about $70 from holden plus labour to code and fit it. Hopefully the housing is not also cracked as they're quite pricey.
    VS Executive S2
    Aug 2010
    melb
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    Check With Your Locksmith First... Some Locksmith Cut Original Keys & Can Replace Barrels Too... GM WILL Charge You An Arm & A Leg... I Used To Work In Holden Parts...
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by cander24 View Post
    I agree.
    Common on VS.
    Get a new uncoded barrel from Holden and have a locksmith recode it to match your existing key blade.
    Its not that hard to do yourself if your'e a bit handy. Just make sure steering lock bar pops out correctly when the key is removed. Check this before you refit the assembly.
    VS Executive S2
    Aug 2010
    melb
    Silicon spray done nothin'. I will contact a locksmith and take it from there. Thanks guys....
    1993 yota 4 runner sr5. Sadly sold vp s
    Oct 2009
    sa
    you should never spray WD40 into a key hole as it takes all the natural lubricant out of it and flushes it away. u should use graphite and rub it on you key and then insert it. by the way when i say graphite i am talking about a lead pencil( made from graphite not lead these days)
    but mate new barrel would be the best bet, lubrication of the barrel wouldnt work it sounds a little more serious than that
    Sep 2010
    Quote Originally Posted by sawychri06 View Post
    I Agree... WD40 etc.. Should Never Be Sprayed Into The Barrel... It Attracts Dirt & Grit, That WILL Damage The Lock..
  1. starter motor solinoid stuck
    By Lowwwerd vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 01:34 PM
  2. cranking not starting
    By bmcleod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2009, 08:43 PM
  3. ignition stuck?
    By Idiot_in_training in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 10:36 AM
  4. ignition its stuck
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 09:34 AM
  5. help! car stuck, worn ignition barrel cant turm
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2005, 12:03 PM
