Results 1 to 20 of 20
Thread: VR Throttle Body help - Urgent!!
    VR Berlina
    Mar 2010
    sa
    Thumbs down VR Throttle Body help - Urgent!!
    Took my throttle body off today for a clean, all went well just putting it back on now and ive got a problem.
    When I took the throttle cable etc off the little spring thing fell apart and I have no idea how it goes back together. Can anyone help please? It's getting dark and i need the car for TAFE tomorrow..
    Also the tensioner pulley has come loose, is it just a matter of tightining the bolt?
    Thanks!
    EDIT: I'm referring to the 2 springs that attack the the little lever thing.. How do these go on properly to make the throttle spring back?
    VR Berlina
    Mar 2010
    sa
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    the 2 return spring on the top that the throttle cable connects to?
    Signature Goes Here
    VR Berlina
    Mar 2010
    sa
    yeah them, they fell off the thing when i took it off and i can't put it back on.. :|
    VR Berlina
    Mar 2010
    sa
    car
    Jul 2006
    greensy, melb
    its not easy, from memory you get one in and the other is a real struggle, i think i used pliers or something to sorta help pull around and pop on but was a while ago
    "A life lived in fear is a life half lived"
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    VR Berlina
    Mar 2010
    sa
    Quote Originally Posted by GenReaper View Post
    What area do you live in, if your up north i may be able to help ?
    Down south sadly. Might just leave it for tomorrow and get someone to come up later. Not a happy chap atm and forcing stuff isn't helping my cause lol.
    Aug 2009
    Radelaide
    VR Berlina
    Mar 2010
    sa
    Maybe ring a taxi for tommorow.
    yer hopefully a mate can give me a lift. thanks for the offer though mate.
    Aug 2009
    Radelaide
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    I'll Post A Pic For Future Reference, When I Find My Camera In The Morning...
    I Just Use A Mild Acid Clean (Bath) For My Throttle Bodies (Without Any Sensors On Though)...
    **Don't Use Throttle & Carburettor Cleaner In The Idle Air Control Holes (Holes Either Side Of Butterfly) Because It Damages The Sensor..**
    Sep 2010
    Thumbs up
    Apologies.. These Pics Are From One Of My Spares That I've Had Sitting For Awhile... (Bit Rusty)
    1: Enertia Springs NEED To Be Sitting In Plastic Case... Top First, Then Put Base On..
    2: Place The Complete Spring Casing On Throttle Body.. With The Two Straight Ends Of The Springs, Resting Just Underneath The Adjustment Screw..
    3: With Butterfly In Idle Position... Manoeuvre The Curved Ends Of Springs In Position (See Pic) While Placing Over Butterfly Bolt...
    4: Replace Spring Washer, If It Is Flat & Tighten Nut (13mm) Until It's Firm & Don't Over-Tight.
    It Took Me About 10 Mins, While Taking Photos... (I Was Going To Do Step By Step Pics, But Thought It's Simple Enough) Hope It Helps..
    I Actually, Got A Quicker Throttle Response Out The Throttle, By Doing This...
    Attached Thumbnails Attached Thumbnails VR Throttle Body  help - Urgent!!-throttle-body-enertia-springs-posistion-without-base....jpg   VR Throttle Body  help - Urgent!!-throttle-body-enertia-spring-final-postion....jpg   VR Throttle Body  help - Urgent!!-throttle-body-enertia-spring-postion-1.jpg
    VR Berlina
    Mar 2010
    sa
    Wow thanks alot QuickVR, just a little too late im afraid.
    Got home from TAFE, print off your pictures and the bloody mechanic arrives, he had no clue and fixed it up with your pictures with me and the swine charged me $87 for 3 minutes work. :|
    Bastards.
  15. #15
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    Quote Originally Posted by Chrispy View Post
    Bastards.
    haha id tell him to get nicked.
  16. #16
    Sep 2010
    No Worries..
    Yeah, It Doesn't Take Long... "It Took Me About 10 Mins, While Taking Photos..." + Taking It Apart First...
    $87.. Yeah, What A Rip-Off... I Wouldn't Of Charged Anything & Given You A Few Business Cards..
    I Would Of Said For Him To Get His Trades Certificate Again Too.. Didn't Bloody Know... Pfft.. Was He Qualified..??
    The Pics Are Up For Future Reference Anyway Now...
  17. #17
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by QuickVRII95 View Post
    carb cleaner works fine IF you don't get it in the TPS sensor or IAC stepper motor
    very simple if you remove sensor and stepper motor or can be done with them in place if a little car is taken. have done this many times without stuffing anything.
    something to be aware of are the needle roller bearing (fitted to the later model TB's) for the butterfly shaft, you don't want to wash all the grease out of these. for the earlier model TB's they don't have bearings fitted so it is even more important
    Body by Holden, Soul by Brock
    the Legend will live forever
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    For the last 6 years Ive sprayed carby and throttle body cleaner all over the IAC and TPS and have never had a problem with either one.I know others that do the same and have never had a problem.I think its just bad luck and a coincidence that someone had a sensor stop working around the same time they cleaned out their throttle body with spray cleaner.Ive heard so many people say not to do this,and Ive yet to see it stuff a sensor up.Theres nothing mentioned on the cans of spray either,you would think they would have to warn you about this if their product could wreck sensors etc.( the cans of cleaner that I have dont mention anything about it anyway).
  19. #19
    Sep 2010
    Quote Originally Posted by Brett_jjj View Post
    Throttle & Carby Cleaner, Reduces The Life Of The Sensors & WILL Stuff Them... You Might Not Notice It... But Someone With A Trained Ear CAN Tell... I Work With Drag Cars etc... & Have ALWAYS Been Told, To NOT Use Throttle & Carby Cleaners On Sensors (It's Designed To Clean Carburettors NOT Really Throttle Bodies.. They Just Add That, To Make You Buy It) & Use MAF Sensor Cleaner..
    MAF Sensor Cleaner from CRC
  20. #20
    simmons001's Avatar
    simmons001 is offline I like VS Caprices
    WH Grange/VS Caprice S1 5.0
    Jul 2005
    Just needed these pics for my VS V8, many thanks to QuickVR for taking the time to post & pic.
    I like VS Caprices so much, I bought 2... and a WH Grange!
  1. throttle body wiring connection *urgent*
    By slidways in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-08-2010, 07:36 PM
  2. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  3. ls1 throttle body, urgent help required
    By VYBR8R in forum LSx Development and Modification
    Last Post: 05-12-2009, 02:32 AM
  4. urgent! - throttle cable black clip broke
    By don0xer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2009, 09:31 PM
  5. **URGENT**Help with twin throttle setup..
    By KRUPTD in forum V8 Development and Modification
    Last Post: 02-04-2008, 06:57 PM
