Results 1 to 2 of 2
Thread: vr 308 starting problem
    vr v8 5ltr
    Sep 2010
    Brisbane, Australia
    Default vr 308 starting problem
    It all started when I snapped the back off my harminic balancer pully wheel, I replaced the oil seal, the harmonic balancer pully wheel, degreased a little bit of oil off( not a lot) went for a drive around the block but 25 meters up the road car backfired then staleed, would not start again, next day changed the plugs and lead, still doesnt want to start, (coughs and farts in the throttle body) had some dodgy mobile machanic come out and all he did was mess up my leads, fix that, have fuel, spark,power, but still doesnt start, can anyone help me , Im puzzled, I never took the distributer out but checked out the cap and rotor, all was good there.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like the water has damaged either (or both) your coil or ignition module. Did you use a hose or a pressure sprayer. Note that EFI V8s are 304 not 308.
  1. VR Starting problem HELP
    By matttid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2011, 11:18 PM
  2. Starting problem
    By ch1mp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2010, 10:32 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VS starting problem
    By mrnathan in forum Electrical Wiring / Questions
    Last Post: 06-06-2006, 09:46 PM
  5. Starting problem
    By UtelemO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 05:30 PM
