Results 1 to 13 of 13
Thread: coolant problem
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Unhappy coolant problem
    Hi all
    I just noticed a little smell tru the heater vents in the cab , when i got home lifted the bonnet
    and noticed the radiator hoses were sucked in and then the over flow from the top up tank belted out
    some coolant the temp was 1/3 so it never got hot . has anyone had simalar problem . PS i took out
    thermastate no diference . any help would be great ?
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Could there be a blockage somewhere within your cooling system mate? I literally have no idea, just throwing ideas in the wind
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Everything has being flushed and new coolant 1000k ago , its got me stumped i just want to
    eliminate the easy things first like thermastate , radiator cap before i jump in and buy water pump
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    If the bottom radiator hose is sucking in,this will stop the coolant flowing properly.There is usually a wire spring inside the lower radiator hose to stop it collapsing or sucking in.Check if the wire spring is still there ,they can corrode away when old, then the hose collapses from the suction of the water pump which then causes overheating problems.
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    Quote Originally Posted by jr689 View Post
    I Agree... Blockage &/Or Leak Somewhere...
    Check The Heater Control Valve On Drivers Side Of Engine... (Hose That Loops To The Firewall..) Or
    It Could Be Your Valley Gasket That's Blown & Sucking Coolant Into The Combustion Chamber...
    (Check Your Exhaust Pipe For Coolant..)
    Is It Running A Bit Rough & Using More Fuel..?? ^^^
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Yeah thanks for that guys both radiator hoses have no spring in them , and she is running smooth as for
    fuel i am pushing to get 400ks a 60l tank i replaced the heater control vaive 3 months ago , coolant is fine
    not droping level .I might replace hoses with springs in them and see how that goe,s .
    Regards Muzz
    vs commodore
    Oct 2009
    Tamworth NSW
    Its really only the bottom radiator hose that collapses if the wire spring corrodes away,thats because of the suction the water pump can generate.They dont make top hoses with the spring inside as the top hose doesnt need it.Id get the engine up to operating temp, and then get someone to rev the engine while you look at the bottom radiator hose to see if it is actually collapsing and blocking off the coolant flow.
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    cheers brett where can you buy the bottom hose with the spring i went to repco and there bottom hoses don,t have the spring ?
    Muzz
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe the lower hoses for the commodores are reinforced some other way and dont need a spring inside them.I dont think my VSV6 has a spring in the bottom hose either,I went and had a quick look at it.Couldnt feel anything like a spring inside it either..I know a lot of other vehicles do use the spring setup though to stop the hose collapsing.Id just check to see if it is actually collapsing first.As I said above,get someone to rev the engine (at operating temp) while you look at the bottom hose to see if it sucks in and collapses as the engine revs rise.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I really don't think bottom hoses need the spring inside to keep them open - that was back when cooling systems ran at 4 psi the Commodore runs at 20 psi which is almost the pressure you run in your tyres. The only time the coolant will flow a maximum rate is when the thermostat is fully open....and then the pressure inside the hose will be near 20 psi less whatever the pump creates.
    A blocked radiator may cause this however, but that is the cause.....a non-collapsible hose will not fix a blocked radiator.....
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Faulty vacuum valve in the radiator cap.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by RX25SE View Post
    I'll second that - something I never thought of....they certainly can get clogged with crap especially if the incorrect coolant has been used.
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Thanks everybody for your input , I reflushed cooling system last night bought a new radiator cap , refilled
    with coolant and everything seems to be running as normal again .Once again thanks everybody and safe travels .
    Regards Muzz
  1. VT coolant problem
    By Niper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2010, 12:36 PM
  2. HELP!!! VT coolant problem
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2009, 03:44 PM
  3. VT coolant problem
    By wolvy29 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2009, 12:23 PM
  4. plz help coolant problem
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 08:09 PM
  5. coolant problem
    By lionheart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 07:45 PM
