buying a stage 2 shift kit and they reckon change the second gear servo 2 but whats the difference between a Billet 2nd gear servo to a Corvette 2nd gear servo ??
just grab the corvette servo and team it up with a transgo shiftkit its more than capable of smashing the insides of the trans the billet is overkill and a waste of money unless you have the most serious engine with at least 300+kw.
"billet" means that it has been machined from a "billet" (i.e. bare block) of material....
So, the "billet" servo is one that has been machined out of a solid block of whatever-grade steel/alloy.
The 'corvette' servo, from the picture, looks like it has been "cast" (i.e. molten metal poured into a casting, then minimal machining done to get the mating surfaces right).
Generally, "billet" parts are stronger than "castings" and are less prone to cracking, etc. (and of course, more expensive)
the billet ones have more pressure force area and are another step or 2 up above the corvette servo for shift harshness
you were correct it is billet alloy v's cast .i run a corvette version ide hate to see what the billet one shifts like![]()
Are you happy with your shift kit delco ?? is it a TransGo Stage 2 ??
billet is the ducks guts of anything automotive and if u wont power and quality it what u need then
but if u just wanna mash gear buy a corvette
