Results 1 to 3 of 3
Thread: need help
    1995 vr v6 statesman
    Sep 2010
    carina (qld)
    Angry need help
    I have recently brought a vr statesman whitch had a dropped cylinder. just replaced the motor and gearbox, started the car and it started fine was blowing bit of white smoke. Let it run for a while and was iling pretty good. Shut it down for the night and the next morning went to start it and nothing just keeps winding over but wont fire. Have checked fault codes but only comes up with 12, all good. Checked spark and has good spark has fuel at the rail, but the plugs are dripping with fuel. This is my first time to this site so any help would be appreciated.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Do a codes check-
    Checking error codes VR/VS (Revised)
    sounds a bit like a dfi?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    so the plugs are dripping with fuel after you tried to start it a heap of times or just after sitting idle for the night? you need 3 to make a fire, air, fuel and spark, so your lacking air from what you've told us. It's also quite likely that even though you have spark it might not be enough to fire an engine though, so you might wanna check coil packs and dfi board as well.
