Hey guys i got a problem with the Vs, If i leave the battery terminals connected over night ill go to start it the next day and the battery is dead, like somethings been draining it.... i thought it might have been the battery so i got a new one, and its still doing it.... what could be the causes of this? alternator?![]()
Not something silly like boot light stuck on?
never thought to check that but i will tomorrow anyway.... With a charged battery it cranks up pretty good, then i drive around for a while come back turn the car off then try to start it again and its sluggish to start it up again,like its been draining while the cars running ..... or as i said before if i let it sit over night with the terminals still connected, by the morning its dead
If All Electricals Are Fine (Lights Not On Etc..)... Take Your Alternator Off & Remove The Regulator On The Back... (Has Plug Attached)...
The Carbon Bushes Are Most Likely Worn & Not Contacting Properly... Make Sure You Remove The Negative Terminal, Before You Touch The Alternator... ZAP!!...
Bosch Regulator Is Only About $37 Inclusive Of GST...
sweet cheers for the advice mate, now lets get back to the other post lol im loving this argument
Also check the B+ terminal at the back of the alternator as they burn out.
Sticky at the top of this forum. VS v6 owners check this out
sweet mate cheers
If there are not any lights left on etc and there is no charge light while driving I'd be checking the diodes in the alternator, one of the field diodes may be faulty.
