it is shuddering from take off and through all the gears can someone please help with this. it has a heavy duty clutch in it. i have only just brought the car
yeah it does and it vibrates while idling and sitting still.
yea i agree with Tom_1569 it sounds like a warped flywheel or something similar ??
engine mounts fine they are still hard. i have just had a look and the clutch cable is adjusted right out so im guessing that the clutch is buggered but will it cause this problem?
Engine mounts may be hard but they still can be sheared. If it was me, I'd eliminate the cheaper options before pulling the clutch out. Is the manual a retrofit? - I thought all VS had Getrag boxes with the dual mass flywheel.
the previous owner had converted it to manual.
The cable being fully adjusted should not cause judder. If it's happening on all gears as you say, and at idle it vibrates, I'd still suspect bad engine mounts. A worn clutch will slip not judder. Another possibility is oil on the clutch - remove the lower cover and see if there is oil on the pressure plate.
if it vibrates at idle as well it could have a flywheel off a vp or vr on it and they are balanced wrong for ecotec
Hmm, could be very badly warped, I would look for something else before Flywheel if it vibrates at idle
My Flywheel is rooted, it vibrates on take off, and kinda vibrates on changing gears, kind of a grip, slip grip thing as it cant grab properly.
At idle the only thing I can is the Throw out bearing grinding away as its ####ed from the flywheel.
The Excedy flywheel is around $750 (T-5 one) or you can get a cheaper version off Not_an_abba_fan for around $350ish I think. Replace your clutch at the same time so both surfaces are flat.
Do not machine, I tryed this, one hard trip of Mt Hotham and she was warped worse.
It is a series 2 and the previous owner has put a t5 in it.
Could be misaligned clutch.
IF it vibrates all the time i will put money on an incorrectly balanced flywheel (seeing as it's converted). I had a wrecker convert my VS with a brand new flywheel, and it vibrated everywhere in the revs. I pulled the 'box out got the pressureplate zeroed and the fly balanced now its all good.
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
A missaligned clutch, would cause the gearbox not to spline in with the clutch
as for the vibration i had the same issue in my old vs..
i never got around to fixing it, got a new box n clutch and machining of the flywheel cause it was shuddering on takeoff ..
I thought it was some kind of balance issue to do with the balance shaft or balancer it self.. tho i never really knew what it was.
Now i own a vs series 2 with a T5 gearbox in it and apart from my button clutch destroying my diff it drives real smoothly![]()
Thanks for the info guys, reading through this has helped me work out the issue i have with my car, looks like its time for a new fly wheel an clutch,
Mine shudders on take off only.
Signature Goes Here
just get ur flywheel machined mate, flywheels are not cheap, especialy if ur running a dual mass like i am .. my flywheel cost me 1000 but its not the standard 1..
super stop brake n clutch (if ur in vic) can test ur flywheel for balance issue and will machine it, as for the clutch, go a heavy duty 1 .. if you can get trade price they a fairly cheap.. i paid 460 for my on/off ceramic plated button clutch
