Results 1 to 10 of 10
Thread: What more todo?
    edals's Avatar
    edals is online now Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Default What more todo?
    Hi Guys.
    I am looking at what to replace mechanical wise with VR. to prevent
    I Have Done Radiator hoses, the Block plastic hose connectors, leads, coolant, trans service, plugs, all filters, inlet gasket, throttle body clean, Coolant Temp sensor to ECU, oil, brake pads, brake fluid, radiator cap, thermostat, engine mounts, Alternator was rebuilt about 2 years ago same with Engine belt being replaced, trans service not to long ago, new key head. is there anything else that is known to let go? that will cause it to become un drivable ? Its happened and got towed 2 weeks ago so going right over to replace anything for piece of mind. I cant think of anything else. i swear i have rebuilt the car now lol
    So share with me what has let go on your VR etc so i can check it out. Its the mrs car and i want it running perfect.
    thanks guys
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    youve covered most things by the looks, water pump is the other thing that can go, but i havn't ever seen it make the car undriveable, it will just have a slow leak.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Well i know the water pump was replaced before we got the car, receipt was in the glove box.
    exhaust has been replaced also to add lol tyres are all pretty new, 80% tread. oh and power steering fluid was replaced less then 2 yrs ago.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    the only other things are like bushes in the suspension, inlet manifold gaskets, shockers, radiator can split, heater tap can leak, heater core can leak (if its been neglected ie ran with water not coolant, cooling system)
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Oh i keep forgetting, All the shocks are done, iv done the heater core the cheaters way lol, and yes i did the inlet gaskets last weekend. heater tap not to old either. radiator is in good condition
    moff_man's Avatar
    Nov 2008
    i think your pretty much set, coils and dfi modules and crank sensors can also die
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    starter motor? leave hammer in boot just in case.
    As also mentioned above, dizzy cap, coil n rotor
    Fuel pump
    car
    Jul 2006
    greensy, melb
    oil pressure sensor, crank angle sensor,manifold air pressure sensor, oxygen sensor and what ever other ones there are
    "A life lived in fear is a life half lived"
