hi guys,
ive got this unstable idle that i cant get rid off..
i have replaced the following
ignition module
tps
iac valve
clean throttle body
clean up the earth wirings
any ideas out there i should try to get this idle much better or am i dreaming off getting a nice idle on a vs v8 due to the age of the car
im thinking next is to change the following
temp sensor as it seems to be worst at first start like big up and downs.
spark plugs and leads , dist cap and rotor button?
after this im out of ideas, am i wasting money trying the above?
oxygen sensor will this help?
maybe a greenfoam tune will fix it up or previous owner has done a cam change and i cant tell coz im new to commodores.
any ideas plz....
my first option would of been new plugs and leads.. why ya there ya can do cap n rotor..
my bet that should fix it...
VR CLUBSPORT WAGONyes a clubsport wagon....
LIVE THE DREAM
Also at check for fuel leaks, espicially where it comes onto the rail. I had this once and it caused a bad hunt around idle
has it got a aftermaket chip
You checked for error codes?
my 5.0 got a ruff idle at the mo after changing plugs n leads but only when its warm..
let me know if ya sus it..
LIVE THE DREAM
you couldnt get a video up of it idling could you?
sure its not just got a big cam in it?
Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
LIVE THE DREAM
somthins up with that. Id keep goin with your little list of things to do. To me it sounds like the spark is drying a bit, so i would start plugs and dizzy and coil if ya think it will help.
Mine used to do pretty much what your's does in that video, even while driving :S. I replaced the dizzy cap, rotor, plugs and leads and it got rid of the problem completely.
Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
yea thats werid, mine only flickers, its real bad when driving tho.. revs are all over the place..
LIVE THE DREAM
yeah gaps are too small, gonna try that n see what happens..
LIVE THE DREAM
I have a haynes VN - VS V6 and V8 workshop manual,It says the plug gap for the VN-VP V8=0.95 - 1.05 mm. And the VR-VS V8=0.8 - 0.9 mm.
