Results 1 to 7 of 7
Thread: vs v8 cranks but won't start
    vs maloo
    Mar 2010
    Default vs v8 cranks but won't start
    Hey tryin to get my vs v8 runnin but it just cranks and won't start. Tried doin a code check but engine light stays on and doesn't flash when I but a papper clip between terminal 5 and 6 on plug under steering wheel. Checked spark and it seems good and fuel pressure was good too. I think the problem is the injectors aren't getting a pulse signal. I unplugged injector wiring plugs and I connected test light between the 2 terminals of injector wiring plug cranked engine and test light didn't flash. This test was in my workshop manual. Can anyone out there give me help or info or suggestions on what could be causing this. Cheers.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id be working out why the check engine light is staying on when the ECU is put into diagnostic mode.The ECU might be buggered.When in diag mode it should flash up any stored error codes, if any are logged.If no error codes are logged, it should constantly flash up a code 12,not just stay on .Maybe try disconnecting the battery for a couple of minutes to reset the ECU.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you have an aftermarket immobiliser fitted it may be playing up.
    Mar 2008
    you will need a noid light to check injector pulse, they are only cheap i got one for around $20
    have you done anything to the engine before the problem started
    can you hear the fuel pump prime when you turn the key
    after it has been cranking pull a spark plug out and see if its dry or wet
    if its a series 3 it should have sequential injection and have a hall effect sensor in the dizzy
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    is it the right key you have?, and is the red blinky imobiliser light going out when you start. This will stop injector pulse.
    Reaper
    VS 5 Litre BT1
    Jul 2006
    Had a similar problem in mne recently...would crank over but not fire. No injector pulse. Turned out to be the Hall Effect Sensor in the dizzy. One new dizzy later and all was good.
    vs maloo
    Mar 2010
    Thanks for your suggestions guys I'll look into it. Cheers
  1. VS Ute cranks over but will not start..
    By BOGANV8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2010, 04:17 PM
  2. vt v6 cranks but doesnt start
    By MY 5.0L VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 11:37 PM
  3. VN cranks but wont start!!!!!!!!
    By redlion05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2009, 02:28 AM
  4. Car Cranks Wont Start
    By GROOVA75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2008, 11:46 PM
  5. cranks but wont start
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 12:03 PM
