Results 1 to 4 of 4
Thread: Door wont open :( Need advice
    1997 VS Commodore Acclaim
    Apr 2009
    Exclamation Door wont open :( Need advice
    Hey guys, so heres whats going on
    Car battery has died, completely. Central locking wont work, door wont open even when I put the key in, so I cant pop the hood 2 jump start the battery. WTF do I do??
    You Cant Kill Whats Stronger Then Death...
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    vs commodore
    Oct 2009
    Tamworth NSW
    If you can get under the car ,see if you can connect a battery charger or jumper lead to the starter motors positive terminal,(the big positive lead that comes from the battery) and the other negetive lead to the body somewhere.This might be enough to power the car up to get it unlocked.(dont try to start the engine like this).Just be careful how the cable is connected to the starter motor terminal.YOU DONT WANT TO SHORT ANYTHING OUT.Be very careful.Jacking up the car, and sitting it on some chassis stands would be the best way,so you can get a good view of it..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can open the bonnet with a very long flat screwdriver by unscrewing the bonnet pin. Also can go in via the boot but you might need to break the plastic catch. Last suggestion is use a second car battery with leads attached to connect + lead to starter motor solenoid and other to car body - then central locking should work as car will have power.
    When you get it open fix the door pronto!
  1. drivers door wont stay open
    By clazzza commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2009, 08:40 PM
  2. Drivers door wont open!
    By wogski in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2009, 09:34 PM
  3. Door locked wont open???
    By reddog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2008, 07:49 PM
  4. Passenger Door Wont open
    By Heffer_Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2007, 01:48 PM
  5. Can't open Door as both handles wont work
    By Bundybeardan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2005, 04:43 PM
