Im trying to figure out if my steering wheel has airbag or not ive done searchs on forum, some ways to tell if i have airbag steering wheel or not would be helpful and appreciated thanks
It will say SRS airbag on the steering wheel horn pad if it has an airbag, if not its just a plain steering wheel![]()
mmmm nup no SRS listed on the steering wheel anywhere its also held in by screws and clips, only thing it has on steering wheel is the holden symbol and the horn symbol
damn and here i was thinking i had airbag
if i go to take cover off just incase should i disconnect battery??
Take the collum surround off, if you see a fluro yellow wire running from the steering wheel into the dash, you sure have an airbag. But when doing any sure of work, weather it be in the engine bay or with electrical, always disconnect your battery.
The wire im talking about is in this picture, just below the horn pad. Isnt the best picture, but a decent reference.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
Air bag light on dash when ignition first switched on?
thanks guys... def do not have an airbag very much appreciate the help :P
