Results 1 to 7 of 7
Thread: Strange sound inside the car.
    VS Executive
    Mar 2010
    Smile Strange sound inside the car.
    i got a 96 executive and when ever i drive i seem to hear a weird sound coming from the front passenger side door, sounds to me like its around the speaker pod area.
    pretty much just sounds like air is coming through somewhere, like a hissing noise.
    and it only happens when i put my foot down.
    i thought for some reason it could be the speaker, so i disconnected that but still there.
    i then checked for leaves in the transfer vents between the door and dash but still heard the noise
    really pissing me off, as i have to constantly listen to music to drown the hissing
    if u got any ideas let me know!!!!!!!11
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VQ Caprice II
    Aug 2006
    sounds like a vacuum hose has come off one of your vacuum modules that controls the vent opening and closing.
    or your door seal has had it.....
    VS Executive
    Mar 2010
    lol no kids
    door seal is fine
    ill try get to that vacuum module, hard to find?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The vacuum answer may be correct...although you do say it happens mainly when you floor the pedal....and that's when there is minimal vacuum so that may rule that out. A method of checking that is to change the vent selector to another setting which them directs the vacuum to another flap....if there is no change then it's probably not vacuum related.
    What does happen when you floor the pedal is heaps of hot exhaust gases are fighting to get out to the real world, and the tiniest of leaks from the manifold or the rest of the exhaust can make a hissing sound. So I'd check the entire exhaust system first....inspect the exhaust header/manifold first as they can crack.
    VS Stato SII L67 S/C V6
    Apr 2004
    I had an odd issue like this, and tracked it down to.......the spring inside the seat height mechanism. Which is obviously near the front speaker pod.
    It sounds like air but it isn't, drove me nuts for ages.
    VS Executive
    Mar 2010
    was it when you put your foot down though.
    yer it kinda starts and stops when its hissing.
    drives me f****ng crazy!
  1. Strange sound from engine bay
    By thebulk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-03-2009, 12:35 PM
  2. strange sound
    By DARK SIDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2009, 06:46 AM
  3. strange whistling sound?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 06:54 PM
  4. New exhaust, Now Strange sound!? Help
    By Cyb3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2006, 04:05 PM
  5. strange gurgle\whoosh noise from inside
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2006, 04:22 PM
Tags for this Thread
