Results 1 to 11 of 11
Thread: VS small oil leak
    Aug 2008
    Default VS small oil leak
    HI
    I have a 95 vs commodore and it's leaking engine oil i think its one of the seals
    it only leaks overnight and it's only one or two drops
    What could be the problem and how can i fix it
    thanks
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Oil filter a bit loose? Otherwise degrease/clean up the engine and then spot the leak easily after a reasonable drive.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    sorry to hijack the thread but I have a small oil leak too, wondering if it could be the rocker covers - how can you tell?
    VS
    Jul 2010
    As mentioned above, clean up the engine and then run the car and look everywhere to see where the leak is.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Just tighten your rocker covers to make sure. Don't do them up too tight thou you will root the gasket.
    VS
    Jul 2010
    Hang on, their a rubber seal aye? Remove and see if theres a break or evidance oil is by passing the seal from the rockers.
    VS S2 Berlina
    Jan 2009
    I just changed my inlet manifold gasket cause that was leaking oil, it can make it look like its coming from everywhere
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    rocket covers can be a main problem on the VS or Rear main seal tighten rocket cover bolts, clean engine bay and report after that
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    As above, you need to get some cans of degreaser and clean down any oily gluggy areas where it could be leaking, then hose it off. Have a look in a few days and see where the oil is coming from. If its coming out of the bottom of the bellhousing and its engine oil, then it will probably be the rear main seal. IMO not worth touching till its really running out, cause it costs a pretty penny to replace that one cause it will be an engine out job. I just got a galvinised tray in my shed with some sand in it. Does the job and i dont worry about it.
    Reaper
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    You don't have to tale the engine out for RMS, just tranny. It's a bastard of a job but very easy on ecotec with the cover plate kit.
  1. power steering rack strange noise and small leak.
    By Kurtp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2010, 10:25 PM
  2. small oil leak
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2009, 02:19 PM
  3. Small radiator leak
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2009, 03:10 PM
  4. small cam in a vy ss
    By vy_ss in forum LSx Development and Modification
    Last Post: 24-03-2009, 10:26 PM
  5. Looking for something small
    By mattman in forum The Pub
    Last Post: 30-06-2006, 06:53 PM
Tags for this Thread
