Results 1 to 15 of 15
Thread: Vr lost all it's fluid
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default Vr lost all it's fluid
    Hi
    A while back I posted about the trans in my vr slipping. Up until the other day ihave been putting up with it.
    Last Sunday I was towing a box trailer with a quad in it with a few mates in the car. Stupid when the trans is slipping I know. Just got up to 100ks on the fwy when I notice a shit load of white smoke behind my car. Quickly pulled over and checked under the car, trans fluid was still dripping from around the trans all over the car and ground.
    I got it towed home and tried to drive it. It started and engaged into D as usual. I only moved it forward so I don't know if it will change gears or not, but I'm thinking if it still engages it mustn't be blown. There has always been oil on the radiator cap, could it be related the the cooling side of things swell.
    What I'm asking is should a put in another trans or should I also grab another radiator?
    I may have broken the law, but that doesn't make it wrong!
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Yer is it coming out of the front or the back
    Or the drain plug...?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    It's hard to say exactly, I've been ski off work all week but will try tomorrow to get it up on ramps. But defiantly behind the engine as it is still clean,
    Car still runs fine though
    vk.jonno's Avatar
    Nov 2009
    south east
    I wouldn't drive it if it lost a #### load of fluid tho
    What did u do to try stop the gears slipping
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    Well about a month or 2 ago I changed fluid and filter with no improvement, and since then nothing. My mechanic says it needs replacing which will hopefully be done this week. But I'm thinking that pressure my be building up somewhere as well since all the fluid was forced out. It was driving fine along the freeway even when the fluid started coming out.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    All you can do is replace the fluid that has been lost - what has happened is that with the transmission slipping, heat has built up and the transmission fluid has boiled over. With a bit of luck, topping the fluid up may get the car going again for a short time.
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    WTF find out where the fluid is coming from check the level how much did u lose, if it was slipping its prob F*^ked
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    Quote Originally Posted by Jacko84 View Post
    I know the trans is gone or at least going. But I'm thinking the radiator may need to be replaced as well. Probe best if I check it out tomorrow to see where the fluid came from exactly. I'll post back then
    VS
    Jul 2010
    Sunshine Coast, Queensland
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    k, had a look under the car today. Cant see a specific area the fluid has come out of. The pan is covered in oil, as are the sides and front of the transmission. Not sure if it could be the rear main seal (not an expert ) or something. Anyway i've got a second hand transmission lined up to get tonight. I'm going to attempt to install it with my dad on the weekend, fingers crossed it all goes well. Anyone able to point me in the direction on this site of a how to or something. Searched but couldn't find anything myself.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    I have one, figured if there was a how to on here I'd read through that aswell
    vs commodore
    Oct 2009
    Tamworth NSW
    You dont really need to read a "how to" when you have a manual there, its all step by step instructions,you cant go wrong.Ive learnt a lot of stuff out of these manuals over the years.They're well worth the money they cost.
  15. #15
    VS
    Jul 2010
    In my opinion its relatively simple, drain the fluid, remove shaft, undo the mount, support with jack, undo the bellhousing bolts, remove the level check, unplug the loom, slide back. And since your changing the box, do the rear main seal. Anyways, thats my opinion on this matter.
  1. power steering made popping sound and lost all fluid very fast.WTF
    By mattyr82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2010, 07:12 PM
  2. I lost my only key. where to from here?
    By my vn calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2009, 12:02 AM
  3. Lost dog, Please help
    By kowan in forum Jokes/Humour
    Last Post: 23-06-2006, 01:46 AM
  4. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  5. Lost 2nd And 4th
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2003, 09:41 PM
