Results 1 to 13 of 13
Thread: Steering noise and vibration
    VR Acclaim
    Sep 2008
    Kingsley WA
    Default Steering noise and vibration
    My son's VR Acclaim puts out low level noise and vibration from the steering that is really only noticeable when turning the wheel while moving slowly - as in backing out of parking bays and moving off. It is not noticeable at speed. Is there a quick fix for this or does fixing it mean a new or reconditioned steering rack?
    ve sv6
    Aug 2010
    it would be more than likley your p/s pump, i would flush the system and put a new one on it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd check where the steering column goes thru the bulkhead - there is a grommet there that dries out and makes a groaning/creaky noise when turning - spray with WD40 from under the car. This fault is very common so I'd try it first. Post back if you need more explanation.
    VR Acclaim
    Sep 2008
    Kingsley WA
    Thanks Glenn, I'll check that out in the morning. And Hako, I was hoping you would come up with a comment. Your experience and guidance in these forums is formidable/incredible. Prior to 2004 when my son bought the car the sole owner lived in a country town and there was a lot of red dust on the underbody and it could have had the effect of drying up around that grommet you mention. Thanks for the tip. I'll let you know how I get on.
    VR Acclaim
    Sep 2008
    Kingsley WA
    VS Acclaim
    Aug 2009
    Just tried WD40 on my VS also.....Quick test drive all seems fixed...thanks heaps guys!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by 08sky_way View Post
    The WD40 sorted it out. Thanks again.
    There's always more than one way to skin a cat!
    vs commodore
    Oct 2009
    Tamworth NSW
    This noise with the steering is a very common problem on these models.When I first bought my VS,when the steering wheel was turned it would make a bad moaning,groaning type of sound.I took it to a couple of places and they looked at it and said the pump and/or rack need replacing etc.I then read on here about the dry steering shaft bush where the steering column shaft passes through the firewall.I sprayed it with WD40 and the noise completely disappeared, and has never come back either.Ive since fixed this on some other peoples cars ,and understandably they were wrapped to have it fixed so easily and cheaply after being told the same thing as me,the pump and/or rack need replacing.I wonder how many people have been caught out like this,got the the rack or pump replaced going on the advice from a "so-called" mechanic, and found they still had the noise there.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    i got told by a so called mechanic that my p/s rack was kaput and leaking and needed replacing and yet in the 1 year i have owned the car i have never had to top up the fluid and the p/s works fine. i tried wd40 which worked great for about a month and then the issue came back. i have also noticed that when my tyre pressure is lower than the recommended level that the creak/groan gets worse. wd40 just doesnt seem to solve this issue permanetly for my car.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    ^^^ Try using a heavier type of spray lubricant such as Wurth HHS2000 or Wynns Viscotene.
    This act more like a grease and last longer. I did mine over 2 years ago and so far, nothing.
    Use a long handled screwdriver to spread the grommet so the spray can get in.
    vs commodore
    Oct 2009
    Tamworth NSW
    I think the main thing is to make sure the spray lube gets right up into the bush.I soaked mine heaps with WD.Its awkward to get at too,and most spray cans wont work properly when used upside down.I got to it a lot easier from up under the car.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Brett_jjj View Post
    I agree.
    Thats how I usually do it.
    Mar 2010
    thanks guys
  1. VZ V6 ute noise and vibration
    By 2005vzute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-06-2010, 12:53 PM
  2. Annoying vibration noise.
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 01:21 PM
  3. Vibration noise ?
    Last Post: 11-07-2008, 01:04 PM
  4. clunking noise and vibration
    By igs_rodino in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 01:31 AM
  5. vibration noise on take off
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 07:36 AM
