Results 1 to 21 of 21
Thread: gear issue
    VS exec 3.8l
    Jan 2010
    Default gear issue
    driving recently began to notice that when in 3rd gear ill hit 120kmph and revs will be at bout 5k, it comes time to shift to 4th (auto transmission), rather then shifting into 4th and revs dropping it hits the shift point drops down and goes back like you were reving the engine in neutral to peak.... not sure why this problem has occured searched it abit but havent found the answer, this only occurs during well "gunning" it when smooth driving it will flick to 4th and keep going no dramas but once foot is down it stuffs up....
    sorry if the explaination is abit shitty, best could explain it...
    Vs Berlina Series 2
    Jun 2010
    yea my vs does it 2... sometimes when im launching off the lights shifting from 1st to second it will stay around 4-5k and wont shift like its slipping or something its ###d and i havent been able to find the answer for it either and seems no1 knos about it.... good luck dude
    92 VP Series 2
    Jan 2009
    East Brisbane
    i dont think it would change anything anyway, but im pretty sure you mean it hits 5k in 2nd gear not 3rd? unless you got an insane gear ratio in your diff lol. your problem seems alot worse than this, but maybe just check your tranny fluid level cos an incorrect fluid level can cause all sorts of problems with gear shifting and drivability. just my thoughts..... good luck ay
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Yes, dont overfill it.
    Get a transmission service kit from repco. Drop the oil/pan, replace filter, clean pan, replace gasket and replenish oil.
    Should rectify smaller issues.
    VS
    Jul 2010
    Any ideas how much fluid it would take from a dead empty trannt, torque conveter and radiator (stock, no after market) it would take? I think i may have to drain some, i put in 8Ls of fluid, havnt started it yet tho.
    Rusty's Avatar
    Mar 2010
    Queensland
    Automatic transmission for VS V6 -
    Total dry refill 7.9L
    Service refill - 4.8L
    use DEXRON III
    Hope that helps
    Rusty's Avatar
    Mar 2010
    Queensland
    VS
    Jul 2010
    Cheers mate, i take it ill need 12Ls as im fairly positive the tranny was dead empty and torque was empty, i know the rad was completely empty. ill prob get away with chucking another 2L in there just to be safe.
    Rusty's Avatar
    Mar 2010
    Queensland
    Dont overfill it, is a major pain to take any oil back out! Should have a sump or something but it doesnt,
    VS
    Jul 2010
    I dont want to over fill it hence why ill only put a total of 10L in and not 12L. Just in case 2L has been hidden somewhere.
    Sorry to hijack your thread mate!
    VS exec 3.8l
    Jan 2010
    i went for another run i hit 120 redlines if i take my foot off gas for few seconds and then gas again it cchanges gear.... but general driving it doesnt have problems... still not sure what to do... il check tranny fluid when i have some light what else could it be
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    seq4x4 - read the posts again! - the capacity of the trans is Automatic transmission for VS V6 -
    use DEXRON III
    The quantities you say you will use (10-12 litres) are for coolant. Plus, you cannot drain more than 4.3 litres from the trans. Overfilling will kill the transmission plus make one hell of a mess on the driveway.
    92 VP Series 2
    Jan 2009
    East Brisbane
    If your trans oil seems to be an ok level then I would still recommend servicing it, but add an additive called lucas transmission fix when you do it. I know alot of people will think a cheap additive will do jack shit but seriously it helped my slipping issues sooo much. For under 20 bucks a bottle at repco what you got to lose? lol just realised I sounded like I work for them or something lol but seriously I recommend it and a basic service, if not a full flush if your oils not so good anymore and its been a while since you last serviced it
  15. #15
    VS
    Jul 2010
    Quote Originally Posted by hako View Post
    use DEXRON III
    Ah true, sorry! I may be, if any, about 1L over full. Cheers for the info as well. Not 100% of the fluid, but it was from super shit auto in 4 liter bottles. Ill find out when i next go there.
    Once again, cheers.
  16. #16
    VS exec 3.8l
    Jan 2010
    okay i tested again, 2nd to 3rd when foot all the way down it wont change gears... just revs at 5k.... if i release pedal for few seconds then gas it again will start gaining more speed no more reving, issue is i use to be able to plant the foot and keep going... why is this problem coming, checked tranny fluid its all good could it be gear box on last legs??
  17. #17
    Rusty's Avatar
    Mar 2010
    Queensland
  18. #18
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do a fault code check as it may indicate a sticky/buggered solenoid in the transmission Checking error codes VR/VS (Revised)
  19. #19
    VS exec 3.8l
    Jan 2010
    All good in terms of the tranny oil filter etc... still same issue, gonna do engine check in sunlight if i get time... but with quick talk to mechanic he said its going from 3rd to 4th gear the clutch (how he worded it) is on way out and is early sign gear box is on way out... means gotta pocket the pennies if that is the case... see what happens, as i said only happens when i plant it all the way down hit 120ish and it revs out,cruising it works perfectly fine... though at 120 if i release gas for few then go again it will let me, so yeh time will tell i guess, if engine check comes up with something then ill know haha otherwise please gear box dont go till i save money :P
  20. #20
    vr
    Jun 2009
    yeah, it does sound like the clutch pack in the trans is stuffed. What colour is the trans fluid? Should be a redish colour. Maybee time for another transmission.
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
  21. #21
    VS exec 3.8l
    Jan 2010
    hmmm tranny fluid smell and look is how it should be as it was only changed like 1 month ago... but early signs gearbox/tranny on last legs so time to save the dollars and make this last aslong as possible haha smooth slow driving here i come... if u get behind me sorry guys ill be going granny speed jks :P
  1. vs ute v8 auto gear box issue
    By mattyking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2010, 01:44 PM
  2. Redline 1st gear & 2nd gear...weird
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 09:02 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. VR Commodore Gear Shift Issue
    By nolim8ts in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2007, 09:52 PM
  5. Electrical issue in reverse gear. VL
    By vlv8vic in forum Electrical Wiring / Questions
    Last Post: 22-09-2005, 04:21 PM
