Results 1 to 24 of 24
Thread: Sway Bar link questions, factory design.
    VL Commodore
    Dec 2008
    Default Sway Bar link questions, factory design.
    Hi,
    So not long since I had my VS and I couldn't notice how the sway bar links were setup, on most other cars they are attached to the LCA's but these are attached to the front shocks and they seem to be creating a resistance on my steering.
    Also I notice the bushes always are sitting at a very uncomfortable position, if I adjust them back and go for a drive they just slide outward again.
    I'm wondering if somebody could give more info on the factory design from what I've read it seems to be flawed as far as the bush wear goes.
    What about steering, is there anyway to improve that? Seems when I got the car jacked up and I am turning the steering wheel, the sway bar links are creating a resistance wanting to pull the wheel back, when driving steering feels much heavier than most cars i've driven.
    The aftermarket ones like Nolathane seem to have a different bush design, and also a S Shaped rod rather than a straight one, not sure why it's S shaped if anybody could shed some light on that.
    Do the aftermarket sway bar links help with steering at all as in make it easier? Or just are designed for a longer life and less wear?
    Thanks.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Get the nolathane ones, the s design take the preload off and sit perfectly. The factory ones are shit design. Not only are the s shaped thicker, but also light as hell. I paid $70 for mine from Auto One. Thats about all i can tell you as thats all i know about the matter
    Dec 2009
    Also from what I have seen the actual Nolathane brand has the best shaped bushes the other cheaper ones do not. There are also other types out now that have ball joints top and bottom however they are a fair bit more expensive.
    The reason Holden conected the sway bar to the strut like that instead of th elower control arm such as in a VB Commodore is that i doing so it increases the effectiveness of the sway bar so they can reduce it's diameter. whatever you do don't conect it to the lower arms as I have seen done on some cars.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    As above there is ball joint links available, and for some reason im thinking back to a conversation i had with a bloke that reconned white line had a kit that totally redesigned the way the sway bay connect up. But maybe someone could shed some light on that one??
    Reaper
    VS
    Jul 2010
    Your talking about sway bar to the z bar i think, whiteline do those also. Id provide links and pictures, but im on dial up and any page with an image takes ages to load, go to the whiteline site, click the options to see whats available for your make and model and itll bring up a list of stuff they have to suit your car and those different designed ones will be there.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by VrWagz1 View Post
    They are the dodgiest looking things I have ever seen.
    I got a pair of the newer style S shaped links with nolathene bushes for $22 sent to my door and the only problem I had was I put the washers on upside down and didn't lock tight them. Or you could go all out and get these. Last price I got was in the vicinity of $160 from Repco
    ve sv6
    Aug 2010
    if your looking side on at the nolathane bush it looks oval shaped which alows the link rod to piviot easyer and not compress the bush helping to stop the bush splitting, work good, the pedders one are the same but they have a straight link rod not the s shaped one. the ball joint type works great because there are no bushes to move and compress giving the sway bar more stiffness and because the balls alow it to piviot easyer. if interested i have 3 sets of the ball joint links, mine are different to the one above but the same deal.
    VS V8 Ute
    Jul 2010
    VL Commodore
    Dec 2008
    Hi,
    Whiteline sells links that allow you to attach it to the lower control arm instead of the shock.
    Interesting, wondering if this provides the same amount (or better?) anti-sway characteristics than the stock setup
    Anyone run these?
    http://www.whiteline.com.au/product_...t_number=KLC18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Do people not read through a thread I have already pointed this product out. I am sure a lot of research has gone into designing it how ever to me it just looks cheap and nasty. I definitely wouldn't feel safe putting that set-up on my car.
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by wraith View Post
    +1 wtf...........
    Reaper
    ve sv6
    Aug 2010
    i have replaced a lot of that whiteline set because of them breaking, just need to put the vx-vy type link on them and there fine after that.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I'm 100% on board with this post.
    The top pic shows the swaybar connection moved from the strut leg to almost half way along the lower control arm. This now moves the point of leverage inboard the distance from the ball joint to the new mounting point. This creates more twisting force on the front bar, effectively reducing its diameter. Fine if thats what you are after.
    The second pics is the better product. This is what I have and never any issues. I tried several types of bushes in the factory links from HQ shocker bushes (soft) to nolothane (hard) and nothing worked. These are the way to go IMHO.
    Dec 2009
    Quote Originally Posted by RX25SE View Post
    Not to mention it adds forces ontot he lower arm that it is not intended to take, imagine breaking a twig by holding it at both ends and pushing on the centre? Your not supposed to jack the front of these cars up from the lower arms, pretty much the same sort of force these links put on the lower arm. I'd be very suspect of this type of setup.
  15. #15
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    the link to the shock is what most companys run eruo cars always are set up like that except some bmw's and older euros it is better in some ways and not in others it would take all day to explain
    there are many options avaliable for your car as you might of heard here
    and for your info all cars are made to have heavier steering so the wheels stay center it's just the newer they get the heavier they get and more power they run into the rack bmw and lexus use electrick racks now as some other companys
  16. #16
    vr berlina
    Aug 2010
    australia
  17. #17
    vr berlina
    Aug 2010
    australia
    and those ball links are useless there meant to have alloy washers not urathane ones the ones i have at work have the alloy washer's
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by vr1uz-fe View Post
    Err what. They have metal washers.....
  19. #19
    vr berlina
    Aug 2010
    australia
    no i mean the red bit's there meant to be alloy
    urathane defeats the purpose as it slows reaction time of the sway bar
  20. #20
    VY SS
    Jun 2006
    Albany
    ive had this setup for about 2 years and never had a problem, im also running the 30mm front swaybar. bought a new car will be selling the VS anyway
  21. #21
    VS
    Jul 2010
    So whats your thoughts on this set up, iv got a 30mm as well, have the nolathane set up, not any that was picture on here. What do you think is better for handling, nolathane or whiteline?
  22. #22
    vr berlina
    Aug 2010
    australia
    they both will be the same if both are 30mm but whiteline has adjustables wich as the name sugestests adjustable in stiffnes
  23. #23
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    The heaver bar compensates for the change to the leverage point.
  24. #24
    ve sv6
    Aug 2010
    nolathanes bars are whitelines just red also same as pedders, and they also come adjustable, as there all the same get what evers cheaper.
  1. help me with sway bar link pin
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2011, 04:57 PM
  2. Sway Bar Link Kit
    By suspicious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2010, 07:33 PM
  3. Sway Bar Link
    By zuluchief in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:28 PM
  4. Sway Bar Link Mod
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 07:14 PM
  5. VN sway bar link kit??
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 03:04 PM
