Results 1 to 4 of 4
Thread: dyno tuning
    VX SS M6
    Jun 2005
    Question dyno tuning
    how much does a standard dyno tune cost
    thinking of gettin it done if not to much
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    I know i'm in QLD but prices would have to be similar. I had mine done at THE BROCK SHOP, Underwood, $197.73.
    Rundown:
    Dyno Run as received for base figure. Checked Spark Plugs. checked ignition leads for resistance. removed throttle body. deglazed carbon. reset IAC valve and decarbon. Download computer diagnostics and check for computer faults if any. check ignition base timing. visual check of computer connections in engine bay.
    Results:
    As tested: 105kw / 140hp @4800rpm
    After Dyno: 111kw / 148hp @4800rpm
    Handy extra 6kw for $200
    P.S - VS stock standard not even cold air when dynoed.
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
    Holden Captiva (Work Demo)
    Feb 2005
    not really worth it unless you have done some major engine work.
    Some people say less talk more action, i say more torque less traction.
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    i figure 6kw for $200 is good value. as well as restoring power to as it should be they check and fix trouble codes, engine runs better afterwards. as i understand it, b4 doing mods it is a good idea to make sure no dramas with engine & computer and everything is as it should be.
  1. Dyno Tuning
    By wozkid in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-01-2010, 09:09 PM
  2. dyno tuning
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-11-2006, 07:05 PM
  3. Dyno tuning a VR
    By muttendagger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2006, 04:16 PM
  4. dyno tuning
    By quick308 in forum General
    Last Post: 27-10-2006, 04:03 PM
