Results 1 to 4 of 4
Thread: Rubbing noise
    vs ss
    Aug 2010
    nz
    Default Rubbing noise
    My SS 5.0 auto is makes a weird cyclical rubbing noise coming from the middle of the dash but could be from engine bay? only does this over apporx 3500 rpm in the higher gears? Also there is a slight rattle at times at idle you can feel through the pedals, is this a busted mount? anyone had similar issues?
    Trans changes smoothly no other issues.
    edals's Avatar
    edals is online now Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Hey mate,
    If ya getting strong Vibrations i would be checking the mounts. Could also be the transmission mount also. Get under the car and see if the mounts look collapsed
    vs ss
    Aug 2010
    nz
    Cheers mate, only vibrates a bit at idle but rubbing noise at high rpm...will check those mounts
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    +1 for mounts
    Reaper
  1. Annoying rubbing noise coming from rear
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 06:03 PM
  2. Rubbing noise - front right wheel
    By Paully in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2010, 08:55 PM
  3. Tyer rubbing noise
    By Ewok in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-03-2009, 11:05 PM
  4. rubbing / struggling noise
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 10:44 PM
  5. bad rubbing noise
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2005, 10:07 PM
