Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: vs just wont start
    Vt ss ls1 6spd /vp berlina 5spd 5ltr
    May 2010
    SA
    Default vs just wont start
    Hey all my mates vs v6 wont start we have changed the following fuel pump fuel filter injectors fuses and relays. we have got half a tank new battery and replaced the coil packs crank angle sensor plugs and leads what else can we do to start her?
    10 liters of aussie v8 cant go wrong
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Is there power to the car, so you turn the car on all lights and acc works? Is the starter kicking over, but theres no fuel or spark to keep it running?
    May 2010
    SA
    yea mate she cranks wont start but with start ya basterd she just fires then wont start n trys to crank again
    VS
    Jul 2010
    Ok, at my guess, were down to a fuel or spark problem. Since you said you replaced the items, are all plugs in properly? Have you ran a diagnostic to see what error codes its chucks at you?
    vs commodore
    Oct 2009
    Tamworth NSW
    If it fires up,but stalls again when you spray start ya bastard into the air intake,that shows there is spark there but no fuel.Id be looking at the fuel side of things.When the ignition key is turned to the on position,can you hear the fuel pump prime for 2 seconds ,then shut off ?
    May 2010
    SA
    shes got fuel we cranked it with a fuel line off and fuel went all over lol and u can hear the pump. How do u put it in diagonostics mode?
    VS
    Jul 2010
    May 2010
    SA
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    vs commodore
    Oct 2009
    Tamworth NSW
    Listen to the injectors as the engine is turned over.Sit a screwdriver on the injector body and carefully put the handle up to your ear,you should be able to hear the injector fire.Is there a good spark?You can get an old or spare spark plug,open up the gap to about 2mm,earth the hex part of the plug to the engine or body,and connect each one of the sparkplug leads to the sparkplug and turn over the engine to check out how the spark is.It should have a strong blue/white spark.Not a weak yellow/red spark.
    May 2010
    SA
    injectors are working and plugs n leads are good and new and put on properly
    vs commodore
    Oct 2009
    Tamworth NSW
    May 2010
    SA
    vs commodore
    Sep 2010
    whyalla
    vs commodore
    Sep 2010
    whyalla
    97 VS V8 manual ute, Holden Torry Hatch, Magna lol
    Sep 2010
    had a old VN vacationer years ago, V6 auto. 2 occassions it wouldn't start. 1st time stuffed harmonic ballancer & the 2nd time seperated the ring gear off the flexplate.. Even with that issue it still wound over because the ring gear would jam but wouldn't start. Guess it didn't like bouncing on the rev limiter for an extended period of time because that's when it let go.
    Probably not helpfull at all lol but something else to look at.
  17. #17
    VS
    Jul 2010
    I think yours cut off because theres a fuel cut off at i think its 5500rpm in park if i remember correctly.
    Ah i was close:
  18. #18
    VS S Pack
    Sep 2009
    You could also check the connection on the DFI module as my mates VS V6 has done the same thing a couple of times, wont start or stops while driving will fire on start ya bastard
    Turned out to be a bad connection to the DFI module
    Chris
  19. #19
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Blockage in the fuel lines? Does the fuel run into the Fuel Lines or what?
    EDIT: Just read you said that fuel poured everywhere.
    Not an electrical issue...Most likely to do with the fuel side of things.
    What do the Error Codes show?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  20. #20
    VS
    Jul 2010
    After reading every new post. Would it have to be done to the rails and/or injectors being block? If fuel comes through the lines, then the last thing in needs to go through is the rails, then injectors, right?
    Also.... What is start you bastard? Lol, sorry its gotta be asked, never heard of it before.
  21. #21
    May 2010
    SA
    diagnostics mode dident work at all lol where is the DFI ?
  22. #22
    May 2010
    SA
    start ya basterd helps to get stubborn engines fired lol
  23. #23
    VS
    Jul 2010
  24. #24
    May 2010
    SA
    it is a spray real flammable lol set my old vh on fire with it lol
  25. #25
    RazzaCaine is offline Long Gone Now
    Mar 2010
    everytime i read "start ya basterd" i thought eh? what is this guy on about haha and now i know
  1. VR V8 wont start when hot...??
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2010, 10:04 AM
  2. air con wont start
    By to_easy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2010, 06:38 PM
  3. Vt wont start and run
    By bladerunnerkim in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2009, 12:10 PM
  4. wont start
    By myvrcomo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 11:07 PM
  5. Help Me, Car wont start!!!
    By Bleaaargh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2006, 05:50 PM
