hey guys only new to the forum and thinking of buying a VS ute
Specs
-2000 series 3 V6 manual
-super low springs over 18's
-hard cover
-Maloo ( i think body kit)
-135ooo kms
it has a fairly bit dent in the tail gate but doesnt look hard to knock it out.
just wondering what sort of common faults Vs utes are known for that i could check for when goin to check this one out.
havent seen the interior or engine bay yet but ill keep u posted once i receive some more photos.
cheers
casey
Just your normal car checks pretty much i'd say. That said though i've been fortunate enough not to have had any problems that have caused a headache.. maybe due to low kms (only about 8k more than the 1 your looking at.... mechanicals (engine/auto) Rear Brakes Disks go quick if it's done some circle work (can't be helped unless you add a brake bias control, bushes, steering, only ute related thing i can say is check behind the passenger seat to make sure someone hasn't cut a bigger hole between the cab & the compartment that houses the fual tank in the tray. Normal place for subs to be mounted & blow through the vent hole there but have seen some people cut the hole bigger to try & get more bass into the cab. Check make sure proper lowered struts not just cut springs.
is it a VT, VU or VS *instert confused face here* lol
2000 would be a vs wouldnt it? my dad has a raven black s3 vs ute, 2000 olympic model. bloody nice ute
I thought they stopped making the VS in 1997......
yea went from 1995-1999 and had special 2000 models, i would just check the radiator and brakes, radiator in mine went bout 130,000k's was original one so they see if any cracks of wearing apart from that they are a pretty decent ute, mines just rolled over 134,000
Cool aslearn something new every day.
I have a 1995 VS Series One ute that I bought from farmer in NSW. He used it as his "grocery car". It's done 96k - body is perfect, only faded paint - which comes up really well with a polish.
I would check for any major panel damage, oil leaks, service histroy? tyre wear and how hard it has worked indicated by the back of the ute !
best of luck.
thanks everyone
i received a email today from him and he said there are also a few little knicks and scratches in the body kit but only if u look had.
only thing that is throwin me off is its in dubbo. fair drive from newcastle, oh well i have family about half way so i could just pull in for the night.
97vsv8- thanks heaps ill be sure to sus out the rear end with a fine tooth comb. the guy who bought my old XG falcon ute cut a big hole behind the passenger seat for the sub, even though its a ford i nearly spewed when he showed me. i think ill just go old skool and make a fibre glass enclourse between the seats.
and yea its a VS, but ill be checking the plates for its Year first.
cheers, casey
You could go to the zoo!
I got mine from Parkes - with it being a country car make sure you check the suspension pretty well as that can be flogged out with the heavy loads they may or may not have had on the back - although from the description and km's i'd doubt it.
Being a manual the gearbox may feel really sloppy as mine did (I had a lot of movement in my gearstick whilst in gear, had the rubbers replaced and it felt brand new again)
It will have the Getrag gearbox and the dual mass clutch/flywheel, both of which are very expensive to repair or replace. Double check these items. I'm not saying that this particular ute is a bad one, but being lowered, with 18's and a dent in the tailgate etc may indicate it's been owned by a young bloke and possible not looked after.
could do the trip in a day easy, be about 4 hours each way
Yeah the 2000 model is an Olympic edition, thats what i got
