Hi does anyone know if i can change the balance shaft bearing in vr v6 without taking motor out Thanks
drill a hole in the firewall..... other wise it cant be done...... the shaft has to come out the back of the engine.
you could try packing it with l90 or similar
Originally Posted by Adam Savage (mythbusters)
the shaft comes out the front but the bearing comes out the rear via welsh plug ide just dissconnect it and forget its in there its what i allways do
i might be wrong than...... it might be the press tool that we have at work is to press the Bearing in, and its way too big to do in the car.....
I remember reading somewhere that the buicks balance shaft can just be taken out? where the ecotec has to have a welsh plug put in its place?
true or bullshit?
ecotech has an oil pressure feed bearing so it needs blocked off or the shaft left in place just unconnected at the front so it doesnt spin
