Results 1 to 13 of 13
Thread: VR (I think!!) Cruise Control Compatibility
    VP
    Sep 2010
    Default VR (I think!!) Cruise Control Compatibility
    Hi all.
    I got a 1994 commodore (actually rebadged as a Toyota Lexcen, but same same, right?!?!?!) and the cruise control doesn't work. Little light comes on the dash saying it is turned on, but that's all.
    I have already replaced the stalk on the column, and checked the switch on the brake pedal, so want to replace the module under the dash.
    Now for the question... anyone know which models of these modules are compatible? I am guessing anything from '90 to about '96... any one know more than me?? (Probably heaps, but we'll see... )
    Thanks in advance,
    Patch
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    the module is the bcm and theirs a bit more than just swapping it over, you need the key head and the correct part number and level.
    have you got any break lights out? this will stop the cruse activating and or check the switches on the pedal for adjustment and condition before swapping the bcm over, and yes vr is 93 to 95 earlier modules wont fit (vn vp)
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    VP
    Sep 2010
    Hi Moff.
    Thanks for the info.
    Have checked the brake lights, and there was one out, but have fixed it and tested the cruise, but still not working, so that wasn't the problem. Have also checked the pedal switches too, and it is working properly.
    Only thing I can think of now is replacing the BCM.
    Patch
    edals's Avatar
    edals is online now Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Could also be the Module under the bonnet as well that controls the cable. Id be looking at swapping that before getting a new BCM
    moff_man's Avatar
    Nov 2008
    also try pressing resume instead of set to see if the new/second hand switch could be faulty mine was, blue wire in the stalk was severed, re sodded and works like new
    VP
    Sep 2010
    Moff, tried pressing both buttons, and nothing. The little green light comes up on the dash to say the cruise is on, but when I try to set it, nothing else works. Is there any way of checking this? Like to see if the module itself is working and it isn't something else that is faulty??
    Have also replaced the entire stem incase the original one was faulty, and no difference.
    Wombat, I did have a look at where the cable attaches onto the throttle arm on the side of the motor and it all seemed pretty good. Is that what you are referring to??
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    did you pull your old switch apart to check for faults ? and just in case, replaced the globe behind the orange ( or green ?) ON sign ?
    VP
    Sep 2010
    Hi Greenacc...
    Do you mean the switch on the stem, or the switch on the pedal? I replaced the stem entirely... and no, I didn't replace the globe behind the "On" sign. Is there another one there somewhere that comes on when the cruise is set? I see the one that comes on when the cruise is first switched on, but the set one doesn't show up.
    The switch on the pedal has been checked and all is working fine there.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Well blown bulb or not you should still be able to set it, just wont glow while its on. still thinking its the module that controls the cable. the car knows it has cruise control but the module just it not setting.
    VP
    Sep 2010
    Edels... that's what I'm thinking. That'll be the next step I think... I've already pulled out the module and will probably head off to GDM tomorrow and find a replacement.
    Also, are the modules from other models compatible with the VR? I suspect VN, VP, VS are compatible... but I'm kinda guessing....
    VR Executive
    Jun 2010
    Rockhampton
    try swapping with a good stalk.i have been fitting cruise to my Executive,with help from Markovr,if you need another BCM,the VR series are different to the VS,you will also need the 2 key heads to suit the BCM.if you have a blown taillight,the cruise won't work.VN-VP don't have BCM,the Module in the engine bay is the same late VP-VS(the ones i have pilfered from VP's all work in my car)
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Brake pedal switch adjustment
    Testing cruise without driving the car
    Stepper motors are the same vn to vs...operating cables are different buick to ecotec to suit different throttle bodies.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. cruise control
    By BUSTER1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-05-2008, 09:39 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
