hey all need to install my rpm tacho does anyone no were i run the green and white wire in a vs thanx
My vz ssz ute
THOSE WHO CRITICIZE OUR GENERATION FORGET WHO RAISED IT
Why do you need two
CHEV badges Australia says no
fighting online is like racing on a special olympic. Even if you were to Win! your still ####ing retarded
Beat me too it.
Also, it should have came with instructions.
1 should be power, one should be coil, one should be lights and one should be ground. Im only guessing.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
i put a different speedo in my car it has no rpm gauge in the cluster yes it has red for power black is earth white is light and green is for coil but WERE do i put the green wire on the coil
My vz ssz ute
No idea. Never had to install one. See if this helps. Rob's Creative Calibrations - Wiring Diagrams
Looking at that, looks to be the BR wire at connector E
On the passenger side harness near the strut there is a wire either folder over or I'll just see the clip that's where it goes
