Results 1 to 4 of 4
Thread: column shift gear box in normal tbar auto
    vs commodore
    Aug 2008
    Default column shift gear box in normal tbar auto
    i have managed to stuff the gearbox in my vs and wondering can you use a column shift auto box in a tbar auto car at all?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've never heard this swap mentioned before but I cannot see any reason why it should not be possible as they are exactly the same transmission. You may need to swap the change lever that attaches to the side of the trans but that will be all. Good Luck.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check that the lever is on the right side for your gearlever is about all to watch out for and that it has the right amount of pins on the plug for the wires
    vs commodore
    Aug 2008
    it looks exactly the same just the bolt where the selecter shaft is longer then the tbar auto set up using this gearbox as a last resort as the wreckers have put it aside for me
  1. [NSW] Column shift auto - prefer vs - can pick up in brisbane, wollongong or geelong
    By jwk87 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-02-2011, 10:52 PM
  2. Urgent! VR column shift auto. start inhibitor switch?
    By GTP 85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2010, 10:19 PM
  3. Gear selector light out on column shift
    By MarzVP in forum Electrical Wiring / Questions
    Last Post: 26-06-2006, 11:54 AM
  4. Removing dash off a VR Ute Column shift auto.
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 02:40 PM
  5. Manual console in a column shift auto
    By Matt H in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2005, 09:29 AM
