just replaced my powersteering pump an its squeeling its guts out when i turn? any ideas got to get it fixed going 4 roadworthy 2morro
did you bleed the air out of it
sure its not the belt?
VR CLUBSPORT WAGONyes a clubsport wagon....
LIVE THE DREAM
just bled it still doing it only when turning belt looks to be good? tryed retighting? at a loss
You have the variable assistance power steering on the Calais? - if so they may use a different pump to normal Commodore, not sure but I know the rack is different. Also the reason/problem/fault you replaced the pump for may have caused damage to the rack and it's internals.(may have fed crap into rack).
whats it sound like ? belt squeal or internal. Check the pulley is lined up with the others, belts not on backwards etc, then rub some wax or soap on the belt and see if it goes away.
