Results 1 to 6 of 6
Thread: Weird cluncking while accelerating
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Weird cluncking while accelerating
    Ok so I've got a 94 acclaim auto acclaim with IRS and when I rake off it cluncking sometimes it'll do while accelerating in every gear. It doesn't do it while ur cruising just accelerating. I've changed the tal shaft..the sound seems to be come from under the car near the auto any ideas
    VX II Calais LS1
    Jan 2010
    broken engine mount
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Right, mate had same problem, the fix i did was for his was just tighten the tail shaft bolts. It turns out the shaft was loose. Even then if its near the box it could be the unis in the shaft.
    Other thing, may not be towards the auto box sound, could be the diff.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Mate give it a carbon clean, take the throttlebody off and remove all the sensors, clena it out thoroughly, do the same with your plenum - just don't let ANYTHING fall into the cylinders!
    I did this to my car last weekend (throttlebody only at this point, doing the plenum soon) and prior to that i had the same issue as you. However it improved dramatically afterwards.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Vr acclaim
    Jun 2010
    I never thout of the gear box mount n diff has a lol play not that much...the tal shaft is tight....might be the unis,,,why would A carbon build up cause clunking???
  1. vy accelerating sound
    By LthlThrt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-02-2010, 10:54 PM
  2. weird noise coming from back when accelerating
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 01:18 AM
  3. VN shuddering when accelerating
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2005, 02:37 PM
  4. Vr Stalling when accelerating
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 08:00 PM
  5. Accelerating (RPM)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 11:21 AM
