Results 1 to 6 of 6
Thread: VR Fuel gauge issues
    93' Pov-Pac
    Jul 2010
    Default VR Fuel gauge issues
    The Fuel Gauge in my VR has been acting up ever since i've had the car. The gauge will go slightly past the full mark when the tank is filled up. Over the course of the week, the gauge will tend to operate normally till it falls to the 5/8 notch, then the gauge will start showing varied readings, it will go down a notch or two and then back up a notch or two, it does gradually fall as the tank empties.
    The gauge will be bung on empty when i near 400k's of driving since fillup, though the car will get me a bit above 500km out of a tank, not the best, but not all that bad given the car's mileage. The cluster is a standard level 2. I was thinking it may be a voltage issue in the cluster causing the issue, though i'm looking for suggestions as to what else it could be as i'm sure someone else has had a similar problem.
    Finally i was thinking of installing something along the lines of a scangauge (it's an aftermarket automotive computer), so i can get instantaneous fuel readouts. Would my issues with the level 2 cluster fuel gauge cause issues with the scangauge?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Sender unit in the tank will be the issue if the gauge works OK when full.
    and 3 Dangerous non ABS VN's
    93' Pov-Pac
    Jul 2010
    Can't really tell if the gauge is ok at full, as it goes slightly past the full mark, and actually can stay there until 100km or so of driving, bit hard to remember atm.
    If it was the sender unit causing the issue, how would that be fixed? I heard that in some cars, a new tank is required.
    88GreenVN's Avatar
    Jun 2006
    The sender unit and second hand pump from the wreckers - $44 or there abouts.
    Check the voltage regulator first as this costs nothing but some time - re solder the joints see if it gets better.
    The tank on full for 100 kms is about right to me. My VN wagon (68 l tank) did 120 ish k's before hitting the full mark - then a steady fall from then on.
    93' Pov-Pac
    Jul 2010
    Checking the regulator first sounds like a good idea, sorry for the dumb question but where would i find that?
    88GreenVN's Avatar
    Jun 2006
    inside the cluster behind the the speedo
    looks like this ---> http://forums.justcommodores.com.au/...-1-cracks.html
  1. fuel gauge issues
    By white vn ss in forum Electrical Wiring / Questions
    Last Post: 25-03-2012, 09:44 PM
  2. Fuel Gauge Issues
    By bigfut in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-04-2009, 01:57 PM
  3. fuel gauge issues..
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 06:33 PM
  4. Fuel gauge issues
    By MikesVT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-11-2006, 03:07 PM
  5. POLL: VZ Ute Fuel Gauge Issues
    By Utester in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-06-2005, 09:17 AM
