are the new tie rod end nuts safe.. i bought a tie rod end yesterday and they don't come with a castellated nut, just a normal screw on nut, should be right ay? im just surprised there different now, no hole to put a split pin either![]()
if its a standed nut put some loctite on it if not see is you can reuse your old one
yeah i think it wasn't just a standard nut had like a plastic lining inside it
that a locnut, it will do fine, just tighten it up to spec and it will hold fine, no need for loctite with those type of nuts
alright mate cheers
Its one of these
Nyloc nut - Wikipedia, the free encyclopedia
They work fine. You just can't reuse them
