hey guys
im new here and looking for some knowledge and help lol
currently im putting a vs v6 into my wb panelvan but am having problems with the oil filter hitting the pitman arm. so i am just wondering if any of the other model commodores oil filter adaptor plates will fit on it allowing me to put the oil filter in a slightly different position to avoid this???
or if any of u have any photos of the different models adaptor plates that i can compare.
anyways, any help would be greatly appreciated
cheers
matt
vn filter mount mounts the filter higher than ecotech and will bolt on
ah ok awesome! thats just wat i need. mite hav to look into it. do u know if the vs power steering pump will be in the way though if i put the vn adaptor plate on? and are the vp or vr any different?
dont know if it will clear pump or not vn pump is up hanging off the drivers side head
ah ok tru. does it tilt the filter slighty down like the vs one? vs pump sounds like its in about the same place. do u know if vp and vr are the same as vn?
The USA verions of this engine mount the oil filter completely different to how ours are, because they mostly mount the engine east-west style and are mostly front wheel drive vehicles.If you dont find anything you can use here is oz,then maybe you can pick one of the US ones up somewhere,online maybe.
ah ok kool. i mite have to look into that! mayb ebay or something has one somewhere. otherwise i guess ill have to go a remote kit or something.
does anyone know if the vp and vr are different or the same as the vn?
same engine, im guessing the same vn s1 was a slight diffrent design with the coolent pipes etc but not sure about the oil filter
Originally Posted by Adam Savage (mythbusters)
i just had a quick look at my 2 engines i have here. the vs oil filter housing sits lower than the vr one but the vr has the pressure sensor out the top, which would hit the p/steering pump on the vs. also the housing will bring it up but the p/steering pump will more than likley get in the way.
ah ok, well that means the adaptor plates on the vn to vr are probably the same. yea i printed some pictures off from this forum last nite of a vn adaptor plate and compared them to my engine... i see what u mean about the power steering pump getting in the way. owell, i mite just hav to get a remote filter kit or something.
