Results 1 to 9 of 9
Thread: Please help very urgent vr exec electrics all gone 1994
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default Please help very urgent vr exec electrics all gone 1994
    Please help i need the car for work tomorrow and nothing works at all.
    Battery is all good.
    I had the interior light on and then turned the ignition over and everything went dead all lights and electrics inside out including central locking.
    Earlier on in the day i heard something like a short and then smelt a little bit off smoke come from the steering column but i started the car 3 times since then until now when everything went dead.
    Is there a fuse or did the computer shit itself or anything worst that could be at fault.
    PLEASE HELP ME.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    vs commodore
    Oct 2009
    Tamworth NSW
    Id also check out the fusible links which are under a smaller cover in front of the fuse box under the bonnet.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    check the fuel pump fuse under the bonit, this powers up the bcm
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    May 2010
    VIC
    Is there a way to tell if the fuses are blown.
    The little fuse box infront off the big one in the drivers side engine bay has a main which is 60 but it doesnt look broken like all the lines are straight and not stuffed like you would find with a 10 or 25 fuse under the dash.
    So could it be a bcm ?
    May 2010
    VIC
    Ok well i sussed it out.
    i heard the BCM clicking after attempting to kick it over.
    I tested all the fuses and there all good i even swapped around all the relays for the F/Pump since the bcm runs off that.
    In the end i was gob smacked and couldn't figure it out so i took out the F/pump fuse and disconnected the negative terminal for 20 seconds i then turned it over after noticing all power was working again and then same thing everything went dead.
    I then re-set it for 10 seconds and then turned it over to accesories and the after the fuel pump kicked in i waited and then turned it over and it started.
    While it was started i tried all electrics and then a few times turned it off and locked the doors and then opened them and re tested it all and it turned over no worries.
    I think my BCM is on its way or just being a bi**ch
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd be looking further before blaming the BCM - the electrical short you heard would have killed the BCM if it came from the BCM unit. I'd be checking the electrical connections at the back of the ignition switch and the switch itself - a bad or loose connection there can cause your problem. I'd also run the fault codes just to see what pops up. Unless you locate the actual fault, it will return....bet your bottom dollar on that.
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by M3ZZA View Post
    the bcm only runs of the fuel pump fuse not the realy
    VL Commodore
    Dec 2008
    I had the exact same problem......Clean battery clamps and terminals, and tighten well.
  1. 1994 vr exec 5 speed
    By nf_vrII in forum VR - VS
    Last Post: 01-01-2011, 10:34 AM
  2. [VIC] 1994 VR Berlina Auto. Urgent sale.
    By MizzVR in forum Vehicles For Sale
    Last Post: 21-08-2010, 06:24 PM
  3. [VIC] VR EXEC. BLUE. 1994. LOW Ks.
    By nathanVY in forum Vehicles For Sale
    Last Post: 05-04-2010, 07:42 PM
  4. Help with Memcal Information (1994 VR Exec)
    By neblol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2009, 11:07 PM
  5. My Vr Exec -- Urgent Sale!
    By tr3nt in forum Vehicles For Sale
    Last Post: 23-09-2007, 01:34 PM
