Results 1 to 3 of 3
Thread: VR oil pressure switch/oil light
    jono1492 is offline DTD
    VE omega
    Dec 2009
    Forrestfield, Perth
    Default VR oil pressure switch/oil light
    hey guys, having some oil warning light issues after replacing my oil pressure switch.
    The other day after driving home from work I noticed a trail of oil leading up to my drive way, I had a look and oil was leaking from the ops, which had been replaced about 6 months ago after the same thing happened. I spoke to an apprentice mechanic mate who said I'd be right to replace it myself. I bought a new one and popped it in with no issues. Afterwards I drove it around my street, no issues, no light. About half hour later I went to drive to the car wash and the oil light is on and stays on.
    Any help would be appreciated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you washed your engine at the carwash you've probably got water in the oil pressure switch...let it dry and hope it comes good. But if it didn't get wet, I'd first make sure there is oil in the sump and then check the wiring to the switch.
    VE omega
    Dec 2009
    Forrestfield, Perth
    The light came on before I went to the actual carwash, but I'll have another poke around tomorrow and check the wiring. cheers
  1. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  2. VY SS oil pressure switch
    By mattyking in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-11-2009, 12:06 PM
  3. VX Oil pressure switch
    By justapeeper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2008, 09:43 PM
  4. Where Is Oil Pressure Switch
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2007, 10:42 PM
  5. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
