Last time i changed a clutch on a ecotech it was a VR and i just put the alignment tool on and bolted it all up and everything was fine
I am about to change a clutch on a VS and my mate is saying the pressure plate should be under load whilst its torqued up
is this the case and if so where do i get the tool
Anything worth shooting is worth shooting twice. Ammo is cheap. Life is expensive.
Never heard of such thing before, i use to do this for a living. We either used a cut input shaft to align it all and bolt it in (tightening the bolts bit by bit going round in a circle till all tight) or if the rare occasion came up we used a clutch aligning tool.
O.o
Tell your mate to lay off the bongs buddy!
A cut off,or old gearbox input shaft is similar to most clutch aligning tools anyway.
Being a VS, it will have the duel mass flywheel. you will need to carefully inspect the flywheel to make sure it is in good condition.
If the flywheel has hot spots or wear marks, you will have to replace it as it can not be machined.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
ah easy money cheers guys
he owes me a beer!
You can just feel around the edge of the pressure plate and align the clutch plate that way. Should be even all the way around. Just have a little load on the pressure plate so the clutch plate can be pushed around to align it. Check alignment by looking straight down the center of the clutch plate.
I think I have used an aligning tool maybe twice. I prefer this method.
Sure if you want to touch the clutch plate and fly wheel. Then you just gave yourself a shudder while you use the clutch. Bolt the fly wheel up, use some good thinners and clean it so no dirt, grease or finger prints are on it. Set up the clutch aligning tool (only touch the sides of the clutch plate) then bolt it up without touch the flywheel or front/back of the clutch plate. Same principal apply to brakes as well.
Never touched the clutch plate. Like I said, the edge.
Probably done 40-50 and never a problem.
Sorry, just miss read it.
+1 u dont NEED a clutch aligning tool it just helps a shitload
