Results 1 to 3 of 3
Thread: 4 hdd in my vr calais
    94 VR series 2 calais
    Sep 2010
    forbes nsw
    Default 4 hdd in my vr calais
    hi all im a new member i have a 4 hdd auto in my 94 s2 vr calais it shutters in reverse it slips at around 3100 rpm can any 1 help me wat is rong is it the bands or t/c thank u
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    is the fluid to the correct level, check when car has been driven to operating temperature then in park with the motor running check the level.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also if the fluid level is correct, then it sounds like the transmission is fairly worn...try doing a fault code check Checking error codes VR/VS (Revised) and see if anything come up. A long shot if the fluid is brown or black, is to do a fluid and filter change and see if that makes any improvement. Last ditch method is to add a can of "transmission stop slip" - this will sometimes keep it going. A reco trans will set you back about $2000 fitted which ain't something to be sneezed at.
    Good Luck and welcome to the forum.
  1. [SA] WTB VL Calais Stock Radio/Casette, Vl Calais Badges
    By reids22 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-08-2010, 05:30 PM
  2. Will factory VN Calais wheels fit over VT brakes on a VN Calais???
    By BEGME2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2010, 11:25 AM
  3. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
  4. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
