Results 1 to 16 of 16
Thread: Possible bearing problem??
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    Lightbulb Possible bearing problem??
    Well i posted last night guys trying to figure out where this "bump bump bump" noise is coming from, anyway took the car for a spin the morning trying to figure out whats making it, The noise increases with speed even with the foot off the accelerator, say at about 60 its most noticeable and goes away when i start to slow down to a stop, I also turned the steering wheel to the left while driving at steady speed and the noise "stops" then straighten the steering wheel back up and it comes back.... jacked up the left wheel this morning, spun it and there's a slight groan that comes and goes as it spins around, and i know its not brake drag because it spins freely, its gotta be the bearings surely??? its just a weird constant knock bump noise while driving.
    Jul 2010
    sunshine coast
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Stick a tire bar (Or just a big crow bar) in the wheel and see if there is any play in the bearing
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Jul 2010
    sunshine coast
    alright ill give it go, its just one thing after the other on this bloody car.... also whats the chances of a con rod/main bearing on its way out in a ecotech? She's as smooth as and plenty of power still.
    Jan 2008
    Quote Originally Posted by Proman View Post
    Depends, do you thrash it?
    Jul 2010
    sunshine coast
    ive only had it for 2 months and drive sensible and don't thrash its got 220 000 on the clock and the people before me that had it didn't look the type that would thrash a car, just used to be a family car i think
    Jan 2008
    What symptoms make you suspect its a main bearing?
    Jul 2010
    sunshine coast
    i dunno im just paranoid about every little sound, whats the easiest way to know if theres oil pressure, the oil light would come on if there was a problem hey??
    vs commodore
    Oct 2009
    Tamworth NSW
    Take the car to a mechanic to get the hot and cold oil pressure readings checked.Cheap and easy.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could also be tyre related as you say it stops when you turn the wheel to the left.....run your hand around the tread of the tyre and feel for any lumps or bulges as it could be a tyre delaminating.
    VR Berlina
    Mar 2010
    sa
    dunno if this helps but is it coming from the back area of the car? I had some bumping noises happening last week and it was the exhaust banging against the chassis. Would only bang under acceleration.
    Was just the rubber exhaust mount that the muffler connected to.
    Jul 2010
    sunshine coast
    VS
    Jul 2010
    Sunshine Coast, Queensland
    If it is the front wheel bearing, best of luck. I tried to remove my disc of the front the other day. Well with a 6LB mini sledge hammer with a towel around it (enough to stop dents and chipping) would not remove the disc.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by seq4x4 View Post
    I came across a similar problem when renewing a mates front discs.They wouldnt come off,even hitting them with a hammer and a piece of wood didnt move them.I ended up removing the 3 allen key bolts that hold the hub to the steering knuckle.Once the disc and hub was off,A couple of heavy hits with a hammer with a heavy piece of wood over the disc,and both sides came off no problem.I used some anti seizeing compound where the disc sits on the hub.Hopefully they should come off easily next time and not seize on there.
  15. #15
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I'm pretty sure on the front discs there's 3 small threaded holes to screw in bolts to lever it off. I've never tried it though.
  16. #16
    VS
    Jul 2010
    Quote Originally Posted by Brett_jjj View Post
    Cheers for the info, ill try that way later on.
  1. Diff Problem, Wheel Bearing or Warpped Disk?
    By Longer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2010, 05:41 PM
  2. Bearing problem
    By Locust in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2008, 02:35 AM
  3. VR Cam bearing problem
    By ozengines in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-08-2008, 10:33 AM
  4. Vibration Problem - Shaft Bearing??
    By Vuute in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2008, 01:02 PM
  5. Air con bearing
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 07:22 PM
