Results 1 to 15 of 15
Thread: Blown head gasket maybe?? any advice??
    VS Executive
    Mar 2010
    Unhappy Blown head gasket maybe?? any advice??
    yer so i think i blew a head gasket like not long ago
    got home, parked, smelt weird smell
    got out
    see the smoke through the lights
    open the bonnet and i see smoke coming from around the rocker covers
    never really blown a head gasket before, so not sure if it would make a sound, becasue i didnt hear anything
    the other thing i think it might be is that i have a crack somewhere cos ive seen a fair bit of oil of my driveway
    anyway
    heres a picture to help
    any advice is greatly appreciated!!!!!!!!!!!!!!!!!!!
    ty. =]
    VS Executive
    Mar 2010
    VS Executive
    Mar 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    Get the cooling system pressure tested,and get the engine compression tested.These tests are fairly cheap to get done.Probably wouldnt hurt to get the hot and cold oil pressure readings checked at the same time.These tests will give you a good idea of the true overall condition of your engine.
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I would say something has definitely let go!
    It is coming from above the rocker cover or from below. Its a bit hard to tell but it looks like the rocker cover is covered in it as well.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VS Executive
    Mar 2010
    yer it the smoke was coming from below
    and yer it did also look like something has sprayed everywhere
    just checked the dipstick then and it was on empty
    so im leaning towards it hopefully being just no oil and getting the crack or whatever it is fixed
    cheers for ze replies btw =]
    Jul 2010
    sunshine coast
    empty? really? is the car on level ground and is the engine cooled down a bit?
    Jul 2010
    sunshine coast
    look under your oil cap then, is there mayo whitish sludgy sh!t on the cap
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Looks like a simple rocker cover gasket leaking badly - eventually they get worse and the oil runs over the exhaust manifold and....smokes. If the engine runs OK after topping the oil up, I'd replace the gasket.
    Jul 2010
    sunshine coast
    James39's Avatar
    James39 is online now Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Second the Rocker Cover or perhaps the Inlet manifold Gasket or maybe the Inlet itself has cracked.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vs commodore
    Oct 2009
    Tamworth NSW
    Just having another look at the pic,that gasket is sticking out the side under the cover,no wonder its leaking oil and smoking,the oil is dripping onto the exhaust manifiold.Just replace the rocker cover gaskets,and only tighten them to the proper specification (7 -11 Nm) .Most people overtighten these covers and it squashes the gaskets which bulges them out like in the pic,which just causes an oil leak again.
  15. #15
    VS Executive
    Mar 2010
    thanks soooooooooooo much for the responses, i know a little bit about cars
    but yer when it comes to these kinda things i know f*ck all
    i might have agood look at it one day and go borrow the service manual and have a nice read
    thanks heaps but guys!
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. Is this a blown head gasket?
    By levymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2009, 05:14 PM
  3. think ive blown a head gasket
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2006, 12:10 AM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. Blown head gasket ?
    By gemini in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2005, 02:38 PM
Tags for this Thread
