Results 1 to 6 of 6
Thread: Resetting ECU - VR Commodore
    93' Pov-Pac
    Jul 2010
    Default Resetting ECU - VR Commodore
    I've just got myself a tuned memcal and i hear that the final part of the installation process is to reset the ECU.
    From what i've read, to reset the ECU the negative terminal of the battery must be disconnected, though there's varying claims of how log it needs to be disconnected, anywhere from as short as 10 mins to as long as 2 hours.
    And then upon starting the car, the car is supposed to be revved up to , and held at approx 2000rpm for 20 seconds, though i've also read that the car may automatically rev itself up.
    If anyone could confirm/deny what i posted above that would be great.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    From my understanding, disconnect for 5mins. Hook back up and drive normally after start up. This applys for the VS, unaware about the VR.
    vs commodore
    Oct 2009
    Tamworth NSW
    Just a couple of minutes with the battery termianal off will be enough to reset the ECU.The gregorys manual for the VP,(I dont have a VR one,but same engine) says, after interrupting the power supply to the ECU,start the engine and rev it above 2000 rpm for a short while to reset the IAC (Idle Air Control) valve.Ive noticed this process is not mentioned in the manuals for the later models with the ecotec engine.
    93' Pov-Pac
    Jul 2010
    Might just go with what the VP gregory's manual says, seeing as its a similar engine, and the ECU should not differ all that much
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    10 seconds is all you need.
    Visit my Facebook page
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    ive always just pulled the engine fuse from the engine bay for 15mins, has always reset it for me, no need to disconnect the battery unless you want to. Then you dont have to reset stereo's etc. The ecotec's rev themselves up anyway about 1200rpm on the first start to relearn the IAC so there's no need to be reving anything really.
  1. Resetting my radio on my VP commodore
    By Vpmark in forum Car Audio
    Last Post: 04-06-2008, 08:59 PM
  2. resetting the cpu
    By over.05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 12:49 PM
  3. Resetting ECU
    By vt busso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2007, 06:37 AM
  4. resetting..
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 12:46 PM
  5. resetting ECU
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2005, 09:16 PM
