Results 1 to 3 of 3
Thread: first car 96 VS ute
    VS 3.8 V6 ute
    Sep 2010
    australia
    Default first car 96 VS ute re spray prep advice please
    hey guys just bought a 96 vs ute with damage to front whole front end as a first car. just fitted new stock front lip , bonnet and side guards and got then sent in to get resprayed ( front end only) the previous paint on the doors and tub is pretty faded in spots and they didnt blend in one ds door. im going to prep the rest of the car myself what sand papers do you guys use... should i go with 130 wet and dry to remove most of the clear coat and paint then dry sand with a 300.. and whats the go with the revision mirrors and the plastic window panels, bumperettes etc also would using builders bog be fine
    VX S Pac L67
    Sep 2010
    WA
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Quote Originally Posted by ChoCo94 View Post
    its nice as i got a dark green 95 s pack ersion its great to drive
    How was that in any way helpful to the O.P?
    O.p have a look through this section, you may be able to pick up some handy tips/hints
    Spray Painting and Panel Beating
    I however cannot offer any advice as i havn't done much large scale spray painting.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
