Hi there,
I was wondaring if ne1 has a electronic speedo cable i think it is or know where i would find 1?? its gotta be 4 a manual commy.....my speedo doesnt go at all
Just change the speed sensor in the gear box for one that works. Thats what I would do.
and 3 Dangerous non ABS VN's
Check the speed alert - if that works it means the speed sensor is OK and the fault is in the speedo. If it's just the odometer not working it will be a stripped cog in the speedo.
we pulled the sensor out and its warned out hard its been repaired to many times....but cant find another to get
